Steptoe Posted September 6, 2018 Share Posted September 6, 2018 Having found that an increase in boost pressure (only double) can cause the alloy "intercooler" cross over pipe from turbo to throttle body - to break ranks and thump the underside of the bonnet....I was wondering if coolant hose clamps would hold better Afterall, cooling system pressure caps are about the mark of double std boost pressure. Has anyone used these for this purpose? I have heard back in the day, rally drivers borrowed fence wire to tie the bloody things to the block. There, 459 kB used of my 2MB allowance Link to comment Share on other sites More sharing options...
ausubaru92 Posted September 6, 2018 Share Posted September 6, 2018 T-Bolt clamps are probably your best bet 1 Link to comment Share on other sites More sharing options...
jono Posted September 6, 2018 Share Posted September 6, 2018 Eyed them off first but lucky us Norma use the size we need onEA82 as the step point change up and down sizes and the flat curved guide is too invasive on the shape of the hose. I tried clamp on hose without fitting to " cooler" pipe Gee, this rain is nice and welcome Might have to suck it and see on this one (& keep some fence wire handy ) Link to comment Share on other sites More sharing options...
carfreak85 Posted September 6, 2018 Share Posted September 6, 2018 Normal worm gear clamps should be more than adequate on any pipe that has a lip or bead rolled into it. Don't reuse the wire clamps, at this age. Link to comment Share on other sites More sharing options...
ausubaru92 Posted September 6, 2018 Share Posted September 6, 2018 So are you running double the factory boost levels? Link to comment Share on other sites More sharing options...
carfreak85 Posted September 6, 2018 Share Posted September 6, 2018 On 9/6/2018 at 7:40 PM, ausubaru92 said: So are you running double the factory boost levels? Expand Who me? I'm currently pushing the stock 14 psi on my EJ20G, soon to be up to 18 psi. Do all your hard pipes have a lip or bead? If not, that's your problem. Once adequately tightened it is basically impossible to blow a worm gear clamp off a properly beaded hard pipe. Are you running 36 psi or a compound charger setup? T-bolt clamps are nice, but they can unevenly clamp around the diameter of the hose, they're heavier, more expensive. Run them if you want (I do on the above set up) but it's honestly an unnecessary expense. Link to comment Share on other sites More sharing options...
ausubaru92 Posted September 6, 2018 Share Posted September 6, 2018 On 9/6/2018 at 8:16 AM, Steptoe said: Having found that an increase in boost pressure (only double) can cause the Expand Nah, quoting Jono Link to comment Share on other sites More sharing options...
jono Posted September 7, 2018 Share Posted September 7, 2018 Factory 6 psi , I had upped it to 12 or 13 and using factory hose and clamps just cruising on boost without changing down a gear...then a thump to the underside sound blanket and then bonnet. All in prep tofor EA82T into my Brumby - frustration plus waiting for the day Link to comment Share on other sites More sharing options...
