lmdew Posted September 9, 2018 Share Posted September 9, 2018 My Kid went out and bought a new 2018 Forester for all of the safety features. I guess those adds work. What should I do to make it last 15+ years. Amsoil oil and trans fluid when it needs changing, what else? Thanks, Larry Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 9, 2018 Share Posted September 9, 2018 Amsoil CVT fluid every 30k if it's the CVT model. Amsoil on all the other fluids also. Signature series 0w20. GD Link to comment Share on other sites More sharing options...
lmdew Posted September 9, 2018 Author Share Posted September 9, 2018 Thanks Link to comment Share on other sites More sharing options...
uniberp1 Posted September 10, 2018 Share Posted September 10, 2018 IMO the best thing you can do use a remote starter and let it warm up before you drive it. Link to comment Share on other sites More sharing options...
lmdew Posted September 13, 2018 Author Share Posted September 13, 2018 GD, CTV drain and fill OK or do you need to do more? I see 3.8 quarts for a drain and fill is that correct? Thanks, Larry Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 14, 2018 Share Posted September 14, 2018 You can do a couple drain and fills with a few hundred miles between. Once you have done it twice you should be good for 30k. Then just do a single drain and fill every 30k. GD Link to comment Share on other sites More sharing options...
lmdew Posted September 14, 2018 Author Share Posted September 14, 2018 Thanks, Larry Link to comment Share on other sites More sharing options...
lmdew Posted October 20, 2018 Author Share Posted October 20, 2018 I did the oil Change today and was going to do the CVT, but then I found this: https://www.subaruforester.org/vbulletin/f89/problems-after-changing-cvt-fluid-782507/index2.html#post7444251 GD what's your shop doing for the CVT? It sounded like drain and fill but it looks like there is quite a bit to the fluid fill to ensure the level is correct. Thanks, Larry Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 21, 2018 Share Posted October 21, 2018 We just drain it, measure what comes out, and put that much back in. Much easier than all that messing around. GD Link to comment Share on other sites More sharing options...
lmdew Posted October 22, 2018 Author Share Posted October 22, 2018 Thanks, that's assuming the correct level was set by the Factory or the Mechanic before you. You know what they say about assuming! Thanks Larry Link to comment Share on other sites More sharing options...
potter2010 Posted October 22, 2018 Share Posted October 22, 2018 A bit of a tangent, but I have a 2010 Outback for a couple years now and maybe I'm horribly wrong but I thought the service schedule said the CVT fluid wasn't to be touched. Did this change on the newer generations or should I quickly change mine? Link to comment Share on other sites More sharing options...
lmdew Posted October 22, 2018 Author Share Posted October 22, 2018 Yep, that's what the Dealer will tell you. GD does a ton of Subaru work at his shop in Portland and recommends ever 30K. Check the SB link above and your service schedule. Amsoil CVT fluid recommended. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 22, 2018 Share Posted October 22, 2018 13 hours ago, lmdew said: Thanks, that's assuming the correct level was set by the Factory or the Mechanic before you. You know what they say about assuming! Thanks Larry True. But generally they are working fine when we do this and if we suspect it's not or see an abnormal amount when we drain it then we will go through the procedure. It's not rocket science and these are really just fancy automatic's with pusher belts and variable pitch pulley's in place of the planetary gearing systems of old. They still have the same basic hydraulic systems, torque converters and clutches of the old conventional auto's. GD Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 22, 2018 Share Posted October 22, 2018 11 hours ago, potter2010 said: A bit of a tangent, but I have a 2010 Outback for a couple years now and maybe I'm horribly wrong but I thought the service schedule said the CVT fluid wasn't to be touched. Did this change on the newer generations or should I quickly change mine? If you believe the marketing claims of lifetime fluid (who's lifetime anyway? The lifetime of the transmission? LOL), then I've got some amazing (magical even) bean investment opportunities for you. Regardless - the manual lays out what conditions the fluid should be changed under - and 90% of all the drivers out there fall under one of the "severe use" conditions - at least in part. And under those conditions the fluid needs to be changed every 25k. So no - it is not lifetime, and really never was. The marketing people got their fingers in that pie and inserted very narrow conditions under which the fluid should last a "lifetime" (the lifetime of the powertrain warranty anyway - 60k - LOL). What a crock. It's sad that people still fall for marketing after being beaten down by it for hundreds of years. GD Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted October 22, 2018 Share Posted October 22, 2018 yeah, I saw a dodge/Mitsubishi manual once that listed operation in ambient temps above 90*F as severe duty ! that's an area like, what/, 1/3 of the contiguous US ? Link to comment Share on other sites More sharing options...
potter2010 Posted October 24, 2018 Share Posted October 24, 2018 On 10/22/2018 at 9:24 AM, GeneralDisorder said: If you believe the marketing claims of lifetime fluid (who's lifetime anyway? The lifetime of the transmission? LOL), then I've got some amazing (magical even) bean investment opportunities for you. ..... What a crock. It's sad that people still fall for marketing after being beaten down by it for hundreds of years. GD Okay, okay. I'll admit I was taken in by this but I've learned my lesson now. I've been looking up the process for a 2010 Outback 2.5 CVT. A few questions: -No one seems to change the filters. Granted it seems like a pain to get to and is rated 'lifetime' (but I've been taken in by that before). Is this something that needs doing? -A few guides mention that a relearning should be done at a shop afterwards. Yes, no? - Amsoil CVT fluid was mentioned as good, if I can't get ahold of this or Subaru fluid, anything else recommended or to stay away from? Thanks! Link to comment Share on other sites More sharing options...
