Dirtbagsubie Posted September 14, 2018 Share Posted September 14, 2018 I pulled the ac components. I did timing belts, water pump and plugs and wires. The car was running before doing this. I did not change timing at all from what it was. It has a weber carb on it. I can now start the car with gas fully depressed. It will only idle while like that. If I let off the car dies. I am confused on why it would do that. I assume a vacuum leak but I can't find one. Quote Link to comment Share on other sites More sharing options...
DaveT Posted September 14, 2018 Share Posted September 14, 2018 #1 thing to check - timing belt procedure. Did you turn the crank 1 full turn between installing the 2 belts? #2 double check the plug wires. When it runs, is it really rough? Either of these will cause this, really hard to start, won't idle, runs like crap, no power. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 14, 2018 Share Posted September 14, 2018 (edited) find the tooth count for you engine on line, pull the covers and check timing as mentioned - align the pulley marks and do a tooth count - belt marks will not be aligned. Edited September 14, 2018 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
pbilt Posted September 19, 2018 Share Posted September 19, 2018 When you did your timing belts which marks on the flywheel did you use the three marks and you line the center one up to the marker on the bellhousing or the top dead center marks on the flywheel Quote Link to comment Share on other sites More sharing options...
Steptoe Posted September 20, 2018 Share Posted September 20, 2018 Yeah. Tell us how you did belts and firing order and direction you believed rotor button turns. We might then better zero in on problem Quote Link to comment Share on other sites More sharing options...
