VectorDave24 Posted September 25, 2018 Share Posted September 25, 2018 I have a 2004 Impreza outback sport. I need to find a replacement for a manual transmission. I'm having no luck at finding one, so I'm looking at other Subarus. Locally I've found a 2003 legacy, a 2003 Impreza, a 2002 Forrester, and a 2004 Forrester. All with manual transmissions. Are any of these compatible with my car? Or is there a resource I can turn to to find out? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 25, 2018 Share Posted September 25, 2018 What's wrong with it? Center diff? Just replace the diff and bearings. They all have that problem. Used isn't going to be a good option. GD Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 25, 2018 Share Posted September 25, 2018 +1 MT's are worth trying to repair. fewer of them around, warn synchro's, input shaft bearings, clutch maintenance, hydraulic solenoid/lines maintenance, expecting maintenance and repair isn't a bad option on MT's. Quote Link to comment Share on other sites More sharing options...
VectorDave24 Posted September 25, 2018 Author Share Posted September 25, 2018 It started out when I lost 5th gear while driving on the interstate. Then a week or two later I think the nut/bolt holding that 5th gear in got into the rest of the gears and messed them up. The diffs seem fine, I think. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 25, 2018 Share Posted September 25, 2018 You think? Have you opened it up? They are easy to repair. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 25, 2018 Share Posted September 25, 2018 (edited) vector - do you have grinding noises or just failure to go into gear? does reverse work? these other guys here are excellent mechs, but not being with the car, you need to shre exactly what's going on. if you do decide to swap, you MUST get a trans with the same final drive ratio. There could also be an issue with how the clutch is operated I think? Edited September 25, 2018 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
VectorDave24 Posted September 25, 2018 Author Share Posted September 25, 2018 25 minutes ago, GeneralDisorder said: You think? Have you opened it up? They are easy to repair. I haven't opened it up yet. I don't have the tools, shop, or knowledge to tackle it all by myself. I have some some research though and talked to a handful of mechanic friends and they all come to the same conclusion. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 25, 2018 Share Posted September 25, 2018 car-part.com will list compatible trans for your car. Quote Link to comment Share on other sites More sharing options...
VectorDave24 Posted September 25, 2018 Author Share Posted September 25, 2018 22 minutes ago, 1 Lucky Texan said: wector - do you have grinding noises or just failure to go into gear? does reverse work? these other guys here are excellent mechs, but not being with the car, you need to shre exactly what's going on. if you do decide to swap, you MUST get a trans with the same final drive ratio. There could also be an issue with how the clutch is operated I think? There are grinding noises and reverse does not work. It is stuck in 4th only. I can't even get it into neutral anymore. I do think that the clutch needs replaced also. How do I find it transmission ratios? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 25, 2018 Share Posted September 25, 2018 well, there you go. run some better oil and frequent change intervals for the new one. you can swap any gear ratio you want if you also swap the rear diff to match and don't mind gearing/speedo being a little off. google 'subaru final drive ratio" or something like that and there is some limited information out there. alternately go to a subaru parts website and look up the rear diff or center diff for your vehicle and click the "applications" tab to see what other vehicles it applies to. some of the subaru parts sites are really slick for this. plug around with that and you can figure it out. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 26, 2018 Share Posted September 26, 2018 (edited) car-part.com , maybe LKQ , their systems already have it figured out and should only show compatible parts. but, if you are shopping craigslist or a pull-a-part yard, take Ido's advice above. There 'may' be a thread at NASIOC with a list of compatible vehicles. I think there were some minor improvements internally on some(?) 2006 and later 5spds if you can find one that's compatible. Edited September 26, 2018 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
