2001 outback at oil temp flashing constantly after head gaskets.
 so i got my moms outback back together today had the engine out for head gaskets timing belt and water pump. everything went well until i went to start it up. the engine runs great however the at oil temp light is now flashing constantly. it does not seem to be experiencing torque bind and seems to drive just like all the other subarus ive driven. what can cause the light to flash constantly? i did not touch any of the transmission connections with exception of the 2 cooler lines at the radiator. is it safe to drive it with the at oil temp light flashing? i would like to get it back home now that the engine back together. its in my uncles garage 7 miles away. fwd fuse did nothing but car was running when i put it in. i took it back out because it did not change the symptom.
Edited by sirtokesalot
If you used a jack on the trans pan....did that once (and only once)...you likely dented it and damaged a wire, etc. on the valve body inside it.
In my case, I managed to break a wire. Dropped the pan,  Soldered it back together, knocked out the dent, and reinstalled the pan....no more blinking.
  • Like 1
Expand
hmmm there is a small dent in the pan i had a jack under it because i dident want the trans to drop down on the frame when the engine separated from it but i also used a 2x6 board from end to end of the pan so i wouldent push in the center. i cannot remember if the dent was in the pan before or not. i was thinking this could be an issue but wasent sure the dent is not very big.
ill have to get the tcu code next time im there i left the car 7 miles away at my uncles garage. i did not want to drive it far with that light blinking. i so far only drove it about a mile to see if there was torque bind (there is not) and transmission seemed to shift fine throgh all gears and again to move it out of the garage to a parking space so the car wasent in my uncles way.
  On 9/28/2018 at 12:41 AM, 3Pin said:
constant flash or a pattern of numbers repeated?
Expand
its lit solid until i start the car and then its just constant flashing at the same rate never stops. im thinking im going to just get the pan gasket and some fluid pull the pan and inspect it.
this car is fighting to stay dead.so first it was head gaskets then the transmission issue. after that it drove 8 miles home sat for 40 minutes and then wouldent start. that metal cap with the o-ring on the fuel pump popped off and blew the o-ring out. so fuel pump came out re attached the cap and bent the metal tab back stuck a hose clamp around it and it ran again managed to put 80 miles on it. my step dad is gonna bring another fuel pump from the parts car when they come to pick it up next week.
  • Like 1
in the past, you could get a cap from an 05 filter kit (throw the filter away), and a 928 metric o-ring for under $75 or so - be sure to inspect any used fuel pump's cap closely - new o-ring would be a good idea too.
check; https://www.amazon.com/Genuine-Subaru-42072AE00A-Fuel-Filter/dp/B00L2OWO2U/ref=sr_1_6?ie=UTF8&qid=1538484308&sr=8-6&keywords=2005+subaru+fuel+filter
there's a 'dimple' on one of the cap's tabs that I guess is intended to be a stop - don't overtighten and force the dimple over the edge of the plastic lug it's on.
Edited by 1 Lucky Texan
  • Like 1
