DaveT Posted September 28, 2018 Share Posted September 28, 2018 How do I check for error codes? Do they show up in a typical scanner for the emissions engine related trouble code, or do I need some other special teader? Quote Link to comment Share on other sites More sharing options...
brus brother Posted September 28, 2018 Share Posted September 28, 2018 do you have the overhead console by the rear view mirror? there was just a write up on how to re-solder connections. check underseat connections. Quote Link to comment Share on other sites More sharing options...
DaveT Posted September 28, 2018 Author Share Posted September 28, 2018 There is a light thing up top, but nothing else on it I noticed. The red error light is on the combination meter. The light for the passenger air bag on / off is center of the dash, at the very top, with the clock, and MPG meter stuff. Got on & off the passenger seat a few times, the light switched on / off as you would expect, but the error light stayed on the entire time. Quote Link to comment Share on other sites More sharing options...
DaveT Posted September 28, 2018 Author Share Posted September 28, 2018 Ok. So when you reconnect the air bag wires, you have to push the little lock thingys all the way in. Do'h! Quote Link to comment Share on other sites More sharing options...
brus brother Posted September 29, 2018 Share Posted September 29, 2018 wires located where? Quote Link to comment Share on other sites More sharing options...
DaveT Posted September 29, 2018 Author Share Posted September 29, 2018 The ones in the steering wheel. On the back of the air bag. Quote Link to comment Share on other sites More sharing options...
