The Cycle Guy Posted September 30, 2018 Share Posted September 30, 2018 Hi, I recently inherited an 86 XT DL, manual trans. My (now deceased) brother-in-law was driving the car 20 years ago when it died, and no one knows why. Car has been sitting in a garage for 20 years, now I'm trying to resurrect it. It cranks over and has spark. Fuel pump doesn't work. I've replaced the fuel pump and relay. I've swapped fuel pump leads both ways. I've checked fusible links and fuses. Still no power to fuel pump. What other things can I check? Could a bad ECU cause this issue? How do you know if the ECU is bad? Thank you all. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 30, 2018 Share Posted September 30, 2018 You have to check power to the pump while cranking. It will only apply power for about 1.5 seconds when you turn on the key. After that it only powers the pump while cranking or running (tach signal present). After sitting for 20 years - very high probability you will need new injectors, fuel pressure regulator, and I would be surprised if it didn't need a new tank. GD 1 Quote Link to comment Share on other sites More sharing options...
naru2 Posted September 30, 2018 Share Posted September 30, 2018 Could be the ECU. Mine failed similarly. Look for 12 volts at the relay coil or ECU pin 19 (blue/red) while cranking to test the ECU. Make sure the other side of the relay coil is grounded as well. Also make sure 12V is available at the relay contacts. I ended up taking power from elsewhere to run the relay. Quote Link to comment Share on other sites More sharing options...
john in KY Posted October 1, 2018 Share Posted October 1, 2018 Did you completely drain the old fuel? I once dealt with 20-year old gasoline and it is nasty stuff. Just mentioning this because the pick-up in the tank could be clogged. 1 Quote Link to comment Share on other sites More sharing options...
