Toadspit Posted October 3, 2018 Share Posted October 3, 2018 98 subaru legacy outback I drove to wichita today and she ran fine all the way there (about 40 or so miles) and everything seemed fine all the way there and most of the way back. I noticed before I made it home that the CEL was on and I read the codes and first it was misfire on #2 . after clearing the codes (I didn't get freeze frame data, I'm a bonehead) I instantly got P0264 I have proper voltage at injector 2 but I am not getting a pulse. I don't have a noid light but I checked a known working injector with the light I have and was able to see the pulse. I was at work while I was trying to sort this out and it got late so I just came home. I'm really hoping it's not the ECM since I'm really strapped for cash right now and driving my gas guzzler van isn't helping any at all. anyone have any suggestions or have run into this before then I'm all ears. Thanks Link to comment Share on other sites More sharing options...
wtdash Posted October 3, 2018 Share Posted October 3, 2018 Check the injector's resistance. Should be about 11-12 ohms? Same injectors as on the '92-'98 2.2, too. Link to comment Share on other sites More sharing options...
Toadspit Posted October 4, 2018 Author Share Posted October 4, 2018 Thanks for responding. I think I found my problem just a few minutes ago. I was out ohm tracing the wires from the pulse wire from the injector in question and discovered that the engine side wiring harness seems to have a bad connection that seems to be right at the back side of the 16 pin connector.I have replaced the 2.5 with a 2.2 from a 96 and I still have the engine harness from the 2.5 so maybe I'll get lucky with it. I just glanced over it and I'm not sure without a side by side comparison but I think it will work. Anybody know if all the sensor connectors are the same plug configuration between the two? Since I am not at the shop with it at this time my lighting situation is less than ideal so I can't visually compare until after work tomorrow Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 4, 2018 Share Posted October 4, 2018 Yeah it's always the chassis to manifold harness connectors. Just cut off the offending wires, and extend them into a westherpack connector. Link to comment Share on other sites More sharing options...
Toadspit Posted October 6, 2018 Author Share Posted October 6, 2018 (edited) What an interesting journey this has been. I decided to retrace this harness with another meter since I remembered some anomalies I had experienced with my old meter some time back. I was on the verge of either removing the intake, fuel rails and all associated electronics when at the last minute I decided it would be a good idea to be pretty dang sure before I butchered Mt harnesses or replaced it. Turns our that I had an intermittent fault in the #2 fuel injector. Fortunately I kept the ones out of the 2.5 before I trashed it. Due to obvious design differences I have swapped all 4 and this 2.2 is running better than it has since I got it. Timing kit is on the way and I think I'll be good for quite some time to come Edited October 6, 2018 by Toadspit Added picture Link to comment Share on other sites More sharing options...
Toadspit Posted October 6, 2018 Author Share Posted October 6, 2018 Link to comment Share on other sites More sharing options...
Toadspit Posted October 6, 2018 Author Share Posted October 6, 2018 Well that didn't quite go as planned lol Link to comment Share on other sites More sharing options...
lmdew Posted October 6, 2018 Share Posted October 6, 2018 Best Subaru out there, a newer Outback with a great 2.2 Enjoy 1 Link to comment Share on other sites More sharing options...
