Evinrude Posted October 7, 2018 Share Posted October 7, 2018 I picked up a 1982 GLF around a week ago from the original owner. I've gotten it running pretty well, installed new tires, etc, but it is in desperate need of some suspension repair. I have spent the past couple of days reading as many threads as I could find, and while there is some good info out there, a lot of it seems to be offroad/lift centered. The problem I'm currently having is that it looks like struts for FWD EA81 cars have been discontinued. So from what I can see, I might have a few options if I can confirm they will work. It looks like EA82 struts will mount up if the 81 strut mount is modified, or if the EA82 mount is used and holes are drilled for the 3 studs. If I can confirm this works, I might go this route. As for FWD EA82 struts, I couldn't find them listed either for 80's cars, but have been able to find them listed for the FWD Loyale Sedan (which should be the same)? I'm using mostly Rock Auto and checking with a local parts distributor for my part listings. Another thing I found is that 4WD struts are still available. Will 4WD struts work if I use my FWD springs; and if so how will that affect the ride height if any? I'm OK if the ride height is raised if I can also raise the rear to match. Thanks in advance for any info. Link to comment Share on other sites More sharing options...
czny Posted October 8, 2018 Share Posted October 8, 2018 https://www.ultimatesubaru.org/forum/topic/150805-ea82-front-struts-fit-ea81/ I have a L & R pair of good used KYB FWD ea82 struts complete with springs & mounts you can have for price of shipping. I cut the brake line tab to make removal easier - just bend it back. PM your address & I would prefer PayPal if you have an account. (Lower 48 US states only - in case someone here asks.) 1 Link to comment Share on other sites More sharing options...
Evinrude Posted October 8, 2018 Author Share Posted October 8, 2018 1 hour ago, czny said: https://www.ultimatesubaru.org/forum/topic/150805-ea82-front-struts-fit-ea81/ I have a L & R pair of good used KYB FWD ea82 struts complete with springs & mounts you can have for price of shipping. I cut the brake line tab to make removal easier - just bend it back. PM your address & I would prefer PayPal if you have an account. (Lower 48 US states only - in case someone here asks.) Wow, perfect. And very generous offer, pm sent about shipping. Link to comment Share on other sites More sharing options...
aba4430 Posted May 13, 2020 Share Posted May 13, 2020 Thread resurrection - Evinrude, how did this project end up? Appreciate an update. Link to comment Share on other sites More sharing options...
Step-a-toe Posted May 16, 2020 Share Posted May 16, 2020 Hey ABA, what aspect interests you? I have done the EA82 struts into EA81 if that is where queries lies Link to comment Share on other sites More sharing options...
aba4430 Posted May 17, 2020 Share Posted May 17, 2020 Yes, that is my query. Did you use the EA81 strut mounts or modify the area to use the EA82 strut mounts. More detail is appreciated. Separately, I have ordered Sachs struts for 4WD EA82 models. They should be delivered by Monday. I don't want to modify the strut mount. Hence curious about your details. TIA. Link to comment Share on other sites More sharing options...
tylertrend Posted May 17, 2020 Share Posted May 17, 2020 Wow this is about the second other GLF besides mine that I know to exist, and mines a 1982 also. Be curious to hear from the OP how this one is holding up. Link to comment Share on other sites More sharing options...
