Sam1968 Posted October 24, 2018 Share Posted October 24, 2018 Hi Everyone: Name is Sam i just joint in , i live in south florida and love to cruise on my outback glad to joint . I have a question . I have replace the IAC valve. EGR valve ,Fuel regulator. Ignition coil and the map sensor .and i still have poor acceleration and when i turn on the car the acceleration goes almost to 3000 to 4000 rpms and goes slowly to 1000 rpms. Can anyone give me some advice on what i need to do or what i did wrong. My next step is to replace the spark plugs. Thanks Guys . Link to comment Share on other sites More sharing options...
idosubaru Posted October 25, 2018 Share Posted October 25, 2018 1. read the check engine codes - what do you get? any national chain can do it for free if you can't. 2. knock sensor is the most common failure on that engine by a mile - i've never seen a cheap $8 ebay special knock sensor fail yet so they're at least a cheap test mule. 3. plugs and wires 4. the timing belt and pulleys are 22 years old and basically worthless for service - they all need replaced. at a minimum check that none are compromised. 1 Link to comment Share on other sites More sharing options...
Sam1968 Posted October 25, 2018 Author Share Posted October 25, 2018 Thank you very much for your great advice, i will get on it asap . Thanks , idosubarus ! Link to comment Share on other sites More sharing options...
el_freddo Posted November 23, 2018 Share Posted November 23, 2018 Got a blocked exhaust/dead cat converter? Cheers Bennie Link to comment Share on other sites More sharing options...
