How does one adjust the Throttle Position Sensor
My daughter has a 96 Legacy Brighton with the EJ22 engine and manual transmission. It has 116,000 miles on it.
I took the Throttle Position Sensor off unaware it has to be adjusted when you put it back on.
The car is still running fine but she says it is slower to accelerate.
I looked in YouTube for some instructional videos but didn’t find one specific to the EJ22 engine.
Page 3 shows how to adjust the TPS.  Remove ECU and check for voltage with the throttle closed (Connector & terminal / Specified voltage (B136) No. 15 — (B136) No. 17 / 0.45 — 0.55 V  [Fully closed.]
From my 99 FSM but should be similar.  But check to make sure the adjustment procedure chosen is for your engine/California emissions etc.
You can get an FSM for your vehicle here
https://sl-i.net/FORUM/showthread.php?18087-Subaru-Factory-Service-Manuals-
MSA5TCD99L94.pdfFetching info...
Edited by Mike104
