comatosellama Posted October 27, 2018 Share Posted October 27, 2018 This is the cause of my car “loping” like a diesel. I’ve been having near constant a/c problems. Seems like the car is out of refrigerant as well. Anyone seen this before? Time to grab a junkyard compressor? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 27, 2018 Share Posted October 27, 2018 Probably over charged. Bumping against the high pressure cutout switch. Have you had the AC *professionally* evacuated and recharged? GD Quote Link to comment Share on other sites More sharing options...
comatosellama Posted October 27, 2018 Author Share Posted October 27, 2018 3 hours ago, GeneralDisorder said: Probably over charged. Bumping against the high pressure cutout switch. Have you had the AC *professionally* evacuated and recharged? GD A/c was serviced probably 8 months ago. When a/c is on and heat is set to cold, you can hear the condenser under the dash trying to fill, but it never does. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted October 28, 2018 Share Posted October 28, 2018 some good info here; https://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/43428-diy-c-air-conditioning-leak-refrigerant-repair-5-less-15-minutes-less.html Quote Link to comment Share on other sites More sharing options...
comatosellama Posted November 15, 2019 Author Share Posted November 15, 2019 the fix was to take off the hex head bolt holding on the clutch, and putting it back on over torqued Quote Link to comment Share on other sites More sharing options...
