Steptoe Posted November 5, 2018 Share Posted November 5, 2018 I recall someone saying EA81 PS does not use the rubber cushioning flange as found on the MS so when looking through my shed started to call it BS. i have a knuckle shaft with rubber flange in my PS kit jus had a look at an old rotting wagon at the back of an a friend's hoard ( hemmed in by only 30 cars or so) It looks non modified and has rubber flange up high just off the steering column then double ? knuckle below before the racks input splined shaft Duscovered that EA82 spfi on EA81 and power steering pump brackets do not go together so time to fit back to original in order to fit PS so I can say I can say I have done it ( and confident in saying it runs good when I try sell it off to highest bidder to fund more tinkering) Link to comment Share on other sites More sharing options...
carfreak85 Posted November 5, 2018 Share Posted November 5, 2018 My EA81T with power steering has a rubber rag joint in the steering shaft. The EA82 w/ PS uses a u-joint instead of a rag joint. Link to comment Share on other sites More sharing options...
jono Posted November 5, 2018 Share Posted November 5, 2018 And that would be where the contributor was confused and did not check facts before posting. Thanks Carfreak Link to comment Share on other sites More sharing options...
el_freddo Posted November 6, 2018 Share Posted November 6, 2018 That user may have been me Jono and Jono That or I had the same convo with a mate when we were sorting something out between the two of us. Anyone know if the EA82 double uni joint can be fitted to the EA81 PS setup? Cheers Bennie Link to comment Share on other sites More sharing options...
carfreak85 Posted November 6, 2018 Share Posted November 6, 2018 On 11/6/2018 at 9:28 AM, el_freddo said: Anyone know if the EA82 double uni joint can be fitted to the EA81 PS setup? Expand It should, as I've read, but I can't confirm it myself. I've got the parts to do it though. Link to comment Share on other sites More sharing options...
