Crazyeights Posted November 9, 2018 Share Posted November 9, 2018 (edited) What is the general opinion on using full synthetic engine oil and gear oil in our older Subarus such as EA81(T) EA82(T) EJ22(T) ? Have you tried any? If so what was your experience? Edited November 9, 2018 by Crazyeights Quote Link to comment Share on other sites More sharing options...
Brianmitchtay Posted November 9, 2018 Share Posted November 9, 2018 I used full synthetic oil for the first few changes after rebuilding the top end of my EA82 when I first bought it, and it leaked considerably worse than regular motor oil does, so now I just use regular. (Granted it was my first engine rebuild ever and I could have just done a better job and my leaks would be considerably smaller). It did run a little more nicely when it was cold in the winter with the synthetic stuff, which was nice. Just my two cents Quote Link to comment Share on other sites More sharing options...
DaveT Posted November 9, 2018 Share Posted November 9, 2018 I never had any Turbos. I've run Amsoil 100% synthetic since the late 80s. And their ATF and gear lube. If it leaks, reseal it. Over 150K and or 10 years old, due anyway. Most noticeable thing is when they are cold, shifting is better - both the auto and standard shift. I run their bypass filters also. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 10, 2018 Share Posted November 10, 2018 Amsoil synthetic in everything I own. EA81, EJ's.... my 86 Trans Am LB9 305 V8. Lawn Mower (Honda), Robin (Subaru) powered pressure washer..... Leaky gaskets actually leak because there's no sludge or varnish in the engine to stop up the holes. If it leaks - reseal it. If you want the junk to last - Amsoil goes a long way toward making that happen. GD Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted November 10, 2018 Author Share Posted November 10, 2018 (edited) 20 minutes ago, GeneralDisorder said: If you want the junk to last - Amsoil goes a long way toward making that happen. GD My engines are more a work of art than junk but thank you for the opinion anyway. I don't trash your "Junk" whatever it is Edited November 10, 2018 by Crazyeights Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 10, 2018 Share Posted November 10, 2018 I refer to most everything as junk. And I trash on most of it. It takes quite a machine to impress me these days. Here's a work of art. 500 AWHP. Yes, I built it. No, it isn't mine: Quote Link to comment Share on other sites More sharing options...
silverhelme Posted November 11, 2018 Share Posted November 11, 2018 (edited) What GD said' if it leaks with synthetic you need to reseal it or didn't seal it correctly to start with. I've done that and had to fix it but sealed right the don't leak. I have four vehicles I run synthetic in. I built the engines in three myself and none leak. Edited November 11, 2018 by silverhelme Quote Link to comment Share on other sites More sharing options...
Myxalplyx Posted November 30, 2018 Share Posted November 30, 2018 On 11/10/2018 at 11:11 AM, GeneralDisorder said: I refer to most everything as junk. And I trash on most of it. It takes quite a machine to impress me these days. Here's a work of art. 500 AWHP. Yes, I built it. No, it isn't mine: Gawd...this is beautiful Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 30, 2018 Share Posted November 30, 2018 Thanks! She's not mine. I just designed and built it. But the customer lets me use it for promotional purposes. GD 1 Quote Link to comment Share on other sites More sharing options...
franbev Posted November 30, 2018 Share Posted November 30, 2018 Don't EA-81engines need zinc in the oil? Since zinc is no longer an additive in "todays" oil I add it separately. Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted November 30, 2018 Share Posted November 30, 2018 54 minutes ago, franbev said: Don't EA-81engines need zinc in the oil? Since zinc is no longer an additive in "todays" oil I add it separately. ZDDP baby, and yes, they need it. I wouldn't add it separately from the oil, you introduce risk of your additives not playing nice with the oil's additive package... Just use a quality oil with high ZDDP: Redline/Amsoil/Euro Castrol/etc. Quote Link to comment Share on other sites More sharing options...
Subarule Posted November 30, 2018 Share Posted November 30, 2018 How would an engine know that it's getting synthetic oil? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 30, 2018 Share Posted November 30, 2018 2 minutes ago, Subarule said: How would an engine know that it's getting synthetic oil? You're supposed to tell them - Old Gen in morse code or smoke signals, new Gen in binary and hex. 2 Quote Link to comment Share on other sites More sharing options...
Subarule Posted December 1, 2018 Share Posted December 1, 2018 6 hours ago, idosubaru said: You're supposed to tell them - Old Gen in morse code or smoke signals, new Gen in binary and hex. Quote Link to comment Share on other sites More sharing options...
jono Posted December 1, 2018 Share Posted December 1, 2018 Basic rule of thumb...if the engine is a dinosaur, lubricate it with a dinosaur ! I thought ATF was a synthetic anyway , a hydraulic type of 'oil' that washes away with a little water Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted December 3, 2018 Share Posted December 3, 2018 On 12/1/2018 at 3:18 PM, jono said: Basic rule of thumb...if the engine is a dinosaur, lubricate it with a dinosaur ! I thought ATF was a synthetic anyway , a hydraulic type of 'oil' that washes away with a little water I disagree with this wholeheartedly. Dino oil is a thing of the past unless your engine is bleeding oil. While many modern synthetic oils are not going to play nice in an older engine, a properly formulated synthetic will run circles around any dino oil. 1 Quote Link to comment Share on other sites More sharing options...
Subuhrue Posted December 3, 2018 Share Posted December 3, 2018 2 hours ago, carfreak85 said: I disagree with this wholeheartedly. Dino oil is a thing of the past unless your engine is bleeding oil. While many modern synthetic oils are not going to play nice in an older engine, a properly formulated synthetic will run circles around any dino oil. Yep. There is a lot of science and work put into new synthetic oils. Quote Link to comment Share on other sites More sharing options...
Steptoe Posted December 4, 2018 Share Posted December 4, 2018 it is your " while many modern synthetic oils are not going to play nice in an older engine" that keeps me with what I know. I am curious as to what synthetics are known to not take bat and ball home with our EA82's though and are the benefits noticeable? Extend oil change intervals etc Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted December 4, 2018 Share Posted December 4, 2018 8 hours ago, Steptoe said: it is your " while many modern synthetic oils are not going to play nice in an older engine" that keeps me with what I know. I am curious as to what synthetics are known to not take bat and ball home with our EA82's though and are the benefits noticeable? Extend oil change intervals etc It's not so much a brand that you can point to, but it takes some research. Basically you need to look at oil analysis for a variety of oils and determine which oil has the best additive package for your engine needs. Flat tappet and older style "high" friction valvetrains are going to want a lot of anti-wear additives, ZDDP, molybdenum, etc. www.bobistheoilguy.com has a fantastic amount of knowledge and recourses. For me personally, in my EJ-turbo engines I run Rotella T6 (because its cheap and sold everywhere). I haven't been driving my old school Subarus enough to require an oil change, thus, I do not yet have a preferred brand of oil for them. Quote Link to comment Share on other sites More sharing options...
