Hitachi leaking Into secondary
Traxx
Got a junkyard carb since mine was missing a few things. Wasnt getting fuel So I cleaned the filter in the carb above the needle float and it fixed it. After that it was getting too much fuel and leaking out of the diagonal port coming from the bowl and somewhere above the secondary. Put a new needle in and it slowed it down and it doesn't seem to leak around the needle. Any ideas? And yes I know, get a weber lol
4 hours ago, GeneralDisorder said:
All this screwing around..... can you just work some extra hours at your job and buy a Weber? Would be more efficient. You can do a Weber for like $250. That's really cheap.
Figured it out right after that. Ended up the float was a couple mm off. I just really don't wanna spend the money on another carb when I can pick up a ej22 for a little more. Main reason why I stopped looking for webers.
  • Like 1
