spideyz Posted June 30, 2004 Share Posted June 30, 2004 So my brats rear end is a little bit too high up in the air. Do you guys know what the "normal" setting is for the rear. I have moved it up and down a little, by adjusting the bolt on the center of the torsion bar, but not sure where it should be for normal driving. I kind of like the way it looks high like that, but when there is no weight in the bed the tires are pointing in at the ground. Cant be good for the tread wear. Keith Link to comment Share on other sites More sharing options...
mcbrat Posted June 30, 2004 Share Posted June 30, 2004 Normal setting will be all the way down. and yes, with any suspension lift/adjustment in the rear, if you do a lot of pavement driving, they will wear fast on the outside edges.... So my brats rear end is a little bit too high up in the air. Do you guys know what the "normal" setting is for the rear. I have moved it up and down a little, by adjusting the bolt on the center of the torsion bar, but not sure where it should be for normal driving. I kind of like the way it looks high like that, but when there is no weight in the bed the tires are pointing in at the ground. Cant be good for the tread wear. Keith Link to comment Share on other sites More sharing options...
