YaBoyKingsley Posted December 3, 2018 Share Posted December 3, 2018 (edited) If I take the front axles out of my brat (properly I won’t just pull them I know they hold the hubs in place) and if I put it in 4wd drive then would I have a rwd brat and would I be able to do donuts but more importantly would it be safe I’m trying to get this brat(1978) to sema 2019 all help would be appreciated if that wont work has anyone mates a rwd drive trani to a ea81(that’s whats going into it the ea71 is getting sold) Edited December 3, 2018 by YaBoyKingsley Forgot some info Link to comment Share on other sites More sharing options...
carfreak85 Posted December 3, 2018 Share Posted December 3, 2018 Yes, it will work. No, it won't last very long and that poor transmission will be dead when you're finished with it. (Ask me how I know...) Link to comment Share on other sites More sharing options...
YaBoyKingsley Posted December 3, 2018 Author Share Posted December 3, 2018 12 minutes ago, carfreak85 said: Yes, it will work. No, it won't last very long and that poor transmission will be dead when you're finished with it. (Ask me how I know...) How do you know Link to comment Share on other sites More sharing options...
carfreak85 Posted December 3, 2018 Share Posted December 3, 2018 In 2008 I converted my EA81T wagon to RWD. It already had the stronger EA82 5-speed transmission swapped in. I also have a clutch type rear LSD and 205/60/13 Yokohama A048 tires. I knew the risks going into the conversion and so I generally only did "RWD" activities in the wet/snow/dirt or other low traction situations. By babying the car I was able to get the RWD conversion to last about four years. But the whole point of the RWD conversion is to have fun, right? Burnouts, doughnuts, drifting, etc. The rear wheel drive system on these cars was only ever meant to hold 40 horsepower or so. Once you direct the engine's full torque to the rear, the RWD transfer gears become a weak link and will shear teeth like its going out of style. You'll end up stranded with a ruined transmission, a non-op Subaru, worn out rear wheel bearings (because they're the wrong style for sliding sideways) and an empty pocket. (But it is fun while it lasts!) 1 Link to comment Share on other sites More sharing options...
Subasaurus Posted December 3, 2018 Share Posted December 3, 2018 29 minutes ago, YaBoyKingsley said: How do you know not suppose to go over 45mph on 4wd, even without the front axles and just having the front wheels running like dummies on the front, there's like 2 warnings of this on the inside of the car itself. sorry to break your dreams, you'll explode that little transmission, same for the EA81, if you can even find a conversion anymore, still woun't work though. Link to comment Share on other sites More sharing options...
Subasaurus Posted December 3, 2018 Share Posted December 3, 2018 just let me know when you blow the diff and transmission apart, i'll be interested to buy a few parts from you when you part it out, keep me in mind! Link to comment Share on other sites More sharing options...
YaBoyKingsley Posted December 3, 2018 Author Share Posted December 3, 2018 3 hours ago, Subasaurus said: just let me know when you blow the diff and transmission apart, i'll be interested to buy a few parts from you when you part it out, keep me in mind! Well I got a spare transmission and what if I where to strengthen the diff’s gears and make nice on all the seals do you think it would last any longer or should I play it safe Link to comment Share on other sites More sharing options...
carfreak85 Posted December 3, 2018 Share Posted December 3, 2018 25 minutes ago, YaBoyKingsley said: Well I got a spare transmission and what if I where to strengthen the diff’s gears and make nice on all the seals do you think it would last any longer or should I play it safe It's not a matter of diff strength, the RWD transfer gears will strip out before anything else fails (besides the rear wheel bearings). Link to comment Share on other sites More sharing options...
YaBoyKingsley Posted December 3, 2018 Author Share Posted December 3, 2018 34 minutes ago, carfreak85 said: It's not a matter of diff strength, the RWD transfer gears will strip out before anything else fails (besides the rear wheel bearings). Thanks well I’ll play it safe Link to comment Share on other sites More sharing options...
