Luvn737s Posted December 6, 2018 Share Posted December 6, 2018 (edited) It’s ready to come out except for a stubborn steering shaft pinch bolt. Can I remove the upper one ( above the u-joint) that is both easier to access and more rigid to reinstall or do I risk screwing something up that’s not obvious. Edited December 6, 2018 by Luvn737s Link to comment Share on other sites More sharing options...
wtdash Posted December 6, 2018 Share Posted December 6, 2018 Hmmm, it's been a few years, but I completely removed mine and it went back together fine. I've read that you need to 'secure' the steering wheel, but likely you've already done that step - if it really matters. Just mark an alignment point on both the shaft and u-joint for reinstall. Link to comment Share on other sites More sharing options...
Luvn737s Posted December 6, 2018 Author Share Posted December 6, 2018 (edited) Taking out the bottom input shaft is a pain. I remember getting it back in was worse. If I took the whole u-joint and all out I could install it on the bench then reattach the upper one which has better access. I don’t want to mess up the airbag sensors though in doing that. Stripping either pinch bolt is my nightmare. I purposely haven’t taken the pinch bolt all the way out to avoid messing up the alignment of the pinch bolt. Edited December 6, 2018 by Luvn737s Link to comment Share on other sites More sharing options...
