silly question, but did you pull up on the hood after pulling the lever? mine releases but does not pop up. I just pull it up, release the safety and open it up. You should be able to see the cable and movement through the grill.
having a helper pull the release while you are looking at things can be helpful.. but yeah, not all of them "pop" up.. they will only move very slightly, then just lift and release the safety catch..
others may need a helping hand pushing downward (too tight) while the release is pulled by a helper
Boy do I feel Silly.  Pushed down on hood a couple of times then pulled hood up. Then went back to release lever in car and back to hood and a little tug and it came right up.
First thing I did was check fluids. All ok. But coolant reserve container was  empty. Should I be worried?
give us more details on the car - miles, trans,  condition, etc.
here's some very brief areas of concern;
early DOHC engines often had headgaskets fail internally - comb. chamber into coolant. (hope major coolant issue isn't why the o'flow bottle is empty)
tires should always be identical or AWD problems can develop - some severe. (same brand/model/size - it matters)
it's easy for folks to be confused and drain/fill incorrect fluids.
many, not all, but many parts need to be OEM or equivalent. (a:f sensors, spark plugs and wires, thermostat, rad,.cap, and axles if possible)
2.5 is an interference engine and timing belt SYSTEM needs to be 'properly' serviced every 105K miles or 105months according to the manual.
Edited by 1 Lucky Texan
Further to this, all travelled the same distance, meaning when it’s time for tyres, replace ALL FOUR. Do not do the replace two, put the best two on the rear trick that you can do with 2wd vehicles.
Cheers
Bennie
Edited by el_freddo
  • Like 1
