Newdesertfoxowner Posted December 15, 2018 Share Posted December 15, 2018 1984 4 speed dual range 4wd. Transmission just started making noise today. It sounds like a light grinding/humming noise. Like a bad bearing. Makes the noise when clutch is engaged but car is in neutral. As soon as I push the clutch pedal down it goes away. Googles telling me a bad input shaft bearing? I'm not a transmission repairman by any means. Any ideas? Link to comment Share on other sites More sharing options...
idosubaru Posted December 15, 2018 Share Posted December 15, 2018 Throw out bearing or input shaft bearing. Not sure how to differentiate, someone will know. I’ve scoured the forum before to figure the diffenrences out. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 15, 2018 Share Posted December 15, 2018 Input shaft bearing. Put in a 5 speed. The 4 speed is garbage. GD Link to comment Share on other sites More sharing options...
Newdesertfoxowner Posted December 15, 2018 Author Share Posted December 15, 2018 On 12/15/2018 at 5:37 AM, GeneralDisorder said: Input shaft bearing. Put in a 5 speed. The 4 speed is garbage. GD Expand I'd like to keep 4wd. Will a newer 5 SPDR bolt up to an ea81? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 15, 2018 Share Posted December 15, 2018 It's been covered in great detail about 100 times on this forum for the last 20 years. Search. GD Link to comment Share on other sites More sharing options...
