moosens Posted December 19, 2018 Share Posted December 19, 2018 (edited) Old days is just look for a Modine and life would be plenty fine for quite a long time. Naturally I see all the cheapies on flee bay. I just went thru my used ones and it seems plastic tanks just don’t like sitting and then being forced back into labor. Read that as second USED radiator to fail on me this year at the plastic reservoir , of course! Advice from empathetic knuckle busters ? Edited December 19, 2018 by moosens Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted December 19, 2018 Share Posted December 19, 2018 If you still have a failed plastic one left I would try taking or shipping it to a radiator shop. They could probably make a metal one that has the same dimensions. It will probably cost some $ though. Quote Link to comment Share on other sites More sharing options...
3Pin Posted December 19, 2018 Share Posted December 19, 2018 try radiator.com Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 19, 2018 Share Posted December 19, 2018 Koyo or Denso. Only. GD Quote Link to comment Share on other sites More sharing options...
Phoenixilva Posted December 20, 2018 Share Posted December 20, 2018 (edited) Rockauto has Denso radiators for ~$75. They're an OE radiator manufacturer for many carmakers, might even be OE for Suabru. Should last a while. Edited December 20, 2018 by Phoenixilva Quote Link to comment Share on other sites More sharing options...
sirtokesalot Posted December 20, 2018 Share Posted December 20, 2018 (edited) is it a manual? not sure if the 95-99 radiator would work but i have one was ment for an auto but the trans cooler fittings leak radiator holds coolant would be great for a manual 20 bucks its a newer radiator boght from junk yard car because it appeared to have been replaced recently then found the trans cooler leaked trans fluid externally from the fittings and couldent get it to stop. Edited December 20, 2018 by sirtokesalot Quote Link to comment Share on other sites More sharing options...
moosens Posted December 21, 2018 Author Share Posted December 21, 2018 It’s a five speed. I’ll likely use an automatic and just cap the tranny cool ports. Kind of common these days with manuals such a small portion of the market. Thanks everyone! Quote Link to comment Share on other sites More sharing options...
moosens Posted December 21, 2018 Author Share Posted December 21, 2018 And thanks sir tokes , but I think I’m going to invest in a fresh unit. Quote Link to comment Share on other sites More sharing options...
