jonathan909 Posted December 22, 2018 Share Posted December 22, 2018 I should have noted the valve clearances before I stripped this motor down, but failed to do so. Before I start pulling the valves out of the heads for cleaning, lapping, new seals, etc., I'd like to get those "before" measurements. But the TSM only gives them based on the rotational position of the right (passenger) side cam sprockets, which doesn't help me a lot with just the left side head on the bench. So is there something that shows what the correct positions of the left side cams are for measuring lash, or is this just a dumb question? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 22, 2018 Share Posted December 22, 2018 Directly opposite the lobe. You always measure lash at the lowest point on the cam which is 180 degrees away from max lift. GD 2 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 22, 2018 Share Posted December 22, 2018 look at the cam lobes where they contact and look for the lowest point. 1 Quote Link to comment Share on other sites More sharing options...
jonathan909 Posted December 22, 2018 Author Share Posted December 22, 2018 Clarification appreciated. Related question: The little tool shown for depressing the lifter (for shim removal/installation) with the cam in place - is it commonly available, or only made by Subaru? I don't see one at Company 23. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 23, 2018 Share Posted December 23, 2018 As it only works for the 97 to 99 25D cylinder heads, it is only made by Subaru's custom tool contractor Kent Moore. I believe that one is close to $400. I have never seen one and since all subsequent dual cam models (except 02 WRX which requires a different tool) require cam removal (shimless bucket), we don't offer the shim replacement service using the special tool. Also I've never been asked to and those engines are now so old if we see one at all we end up doing pistons and head gaskets making the tool useless anyway. GD Quote Link to comment Share on other sites More sharing options...
jonathan909 Posted December 23, 2018 Author Share Posted December 23, 2018 Thanks - I don't think I'll be bothering Santa over this one. Quote Link to comment Share on other sites More sharing options...
