Window replacement tips?
Hey guys. While I was at work this weekend someone smashed the driver side, back seat window out of my 89 wagon. I know where 1 is at a junk yard but I've never swapped a window before. Anything I need to know before I go get it today?
Thereis a lot to take apart.    The FSM has pretty detailed information on this.   I have removed several.   Iirc, you need 10mm and 12mm sockets.  And a Philips screwdriver.   Assortment of pliers and flat drivers wouldn't hurt to have.
You can un bolt the glass from the regulator mech.   You might have to move the position up and down to get at all of the bolts.
  • Like 1
I don't think so, I dont have a computer. I meant to write sooner, but I got it figured out. I just had to mark the tabs that I think limit how high the window actually goes up and loosen those and everything worked fine. Hardest part of the job was getting what was left of the old window out of the tracks because of the broken glass above the rollers.
