wysubey Posted December 26, 2018 Share Posted December 26, 2018 Hi, Got my ECT replaced, wow what a difference! Baby runs so much better now. Still throwing code 34 - EGR solenoid or circuit. Pulled off the EGR valve and cleaned it. I'm able to move the diaphragm by hand while engine is idling, rpms drop as expected. My ohm meter shows open circuit across the vacuum solenoid. No clicking at all when 12v is applied. Next step is to replace it. Looks like Hitachi # W0133-1624136 is the replacement. My question is this: is there a bolt-on EGR valve that actuate with 12v instead of vacuum pressure? Basically bypass the vacuum solenoid & mechanical valve. Actuate it directly with electrons like more modern EGRs. Simpler and maybe more reliable. Or will a electromechanical valve pull too much current for the ECU? Thanks all- here's to keeping the EA's alive Quote Link to comment Share on other sites More sharing options...
DaveT Posted December 27, 2018 Share Posted December 27, 2018 (edited) The function would not be correct. The solenoid disables the egr while the ECU reads that the engine is not up to normal operating temperature. The Subaru solenoids die. I have Toyota ones in mine, that are still working, since 1988. There are a few threads on the forum with the link to my Web page about the mod. Later I can add it here. Edited December 27, 2018 by DaveT fixed typo Quote Link to comment Share on other sites More sharing options...
DaveT Posted December 27, 2018 Share Posted December 27, 2018 http://www.dynahoedave.co.nf/solenoid.html Solenoid upgrade Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 27, 2018 Share Posted December 27, 2018 You just wire up any 12v solenoid valve. The ECU only cares about the solenoid resistance. It doesn't even matter if the EGR actually works or not. GD 1 Quote Link to comment Share on other sites More sharing options...
wysubey Posted December 27, 2018 Author Share Posted December 27, 2018 Thanks Dave & GD. I'll look around for a Toyota solenoid. Quote Link to comment Share on other sites More sharing options...
Crazyeights Posted December 29, 2018 Share Posted December 29, 2018 (edited) The solenoids I grabbed that work were off a 1992 Toyota Paseo Edited December 29, 2018 by Crazyeights Quote Link to comment Share on other sites More sharing options...
wysubey Posted December 31, 2018 Author Share Posted December 31, 2018 I bought the OEM one for this repair... working great now. If this one dies in a short period I'll get one of your recommendations. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
