YnotDIY Posted December 27, 2018 Share Posted December 27, 2018 Hey Everyone, I apologize for the parts question. I'm really not familiar with terms, but am trying hard to learn. I'm looking for an axle seal for the transmission side of my 88 GL. I've got transmission oil leaking out of the passenger side axle where it meets the transmission. Can someone please comment with a link, part number, and name of this seal. Right now I'm just putting a bunch of seals into my cart on Rock Auto hoping that one of them will be correct. I've got.... Input Shaft Seal Output Shaft Seal Drive Axle Seal Extension Seal Axle Shaft Seal (this is the one I think it is, listed as front outer, but there is no image) Thanks so much! I'm moving to Chicago and hoping to get everything I need to seal this up before I take off. The help is always appreciated. Quote Link to comment Share on other sites More sharing options...
el_freddo Posted December 27, 2018 Share Posted December 27, 2018 806730031 - OILSEAL-30X50X9 RH 806730032 - OILSEAL-30X50X9 LH these seals are RH and LH specific. You’ll also want one of these for each side: 806975010 - O RING,74.5X2 I hope this helps out. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
YnotDIY Posted December 27, 2018 Author Share Posted December 27, 2018 Thanks @el_freddo , this helped a ton! Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 27, 2018 Share Posted December 27, 2018 Just call a dealer that has the parts book and tell them you want all the seals that are still available for the trans. GD 1 Quote Link to comment Share on other sites More sharing options...
YnotDIY Posted December 27, 2018 Author Share Posted December 27, 2018 Not a bad move. Thanks GD. I called my local shop and the guy goes "oh here we go" like I wasn't going to have the correct numbers. Everything checked out Bennie. Funny they had the 31 seal in stock, but not the 32. They are definitely side specific? They had everything else as well. Thinking a 2.2 swap is in my future. Probably in the next few years. Honestly it sounds fun to me. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 27, 2018 Share Posted December 27, 2018 Yes they are side specific. The seals have tiny ribs on the lip that guide the gear oil back into the trans when driving forward. The angle of the ribs matters. But it's a jelly-bean part. You can measure the seal, order a standard off-the-shelf lip seal of the correct dimensions and it will work fine. Subaru used directional seals sometimes, and other times not. Both styles can be seen in various years of the R160 rear diff seals. Both work just fine. A generic, size matched, non directional seal would do the same job. The directional seal was overly cautious and overly engineered. GD Quote Link to comment Share on other sites More sharing options...
YnotDIY Posted December 27, 2018 Author Share Posted December 27, 2018 Thanks GD, this is good to know for the future....not that I'll be changing these on this car ever again while I have it. haha cheers! Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted December 28, 2018 Share Posted December 28, 2018 Look those part numbers up on a subaru parts site and you'll see why they had most everything in stock. Quote Link to comment Share on other sites More sharing options...
YnotDIY Posted December 28, 2018 Author Share Posted December 28, 2018 @86BRATMAN haha yeah I did. These parts cross over a bunch of years. Well into the 2000's. Quote Link to comment Share on other sites More sharing options...
el_freddo Posted December 28, 2018 Share Posted December 28, 2018 3 hours ago, YnotDIY said: @86BRATMAN haha yeah I did. These parts cross over a bunch of years. Well into the 2000's. Yeah they do That’s one of the reasons why I knew they could be found. The painful part is that the MT diff was listed AFTER the Auto Trans. That took me a moment or two to work out... Cheers Bennie 1 Quote Link to comment Share on other sites More sharing options...
YnotDIY Posted December 31, 2018 Author Share Posted December 31, 2018 So just checking but, seals that are 30x50x9 should work? Like these? >> https://www.amazon.com/Subaru-Legacy-Forester-Outback-Impreza/dp/B0798TD5BM/ref=pd_lpo_sbs_263_img_1?_encoding=UTF8&psc=1&refRID=VWDVXTZ3ZJNBHXHAH76P Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 31, 2018 Share Posted December 31, 2018 Should work, yes. GD Quote Link to comment Share on other sites More sharing options...
YnotDIY Posted December 31, 2018 Author Share Posted December 31, 2018 awesome, thanks @GeneralDisorder. Got both LH and RH today. Will be swapping them tomorrow. I'll post some pics. Quote Link to comment Share on other sites More sharing options...
rae houghton Posted March 3, 2019 Share Posted March 3, 2019 If you have time to post pics, would love to see them. I suppose when a person pulls out a tranny, and puts it back, or replaces it, the seals should always be replaced???? This is a real question to anyone caring to answer. Quote Link to comment Share on other sites More sharing options...
el_freddo Posted March 3, 2019 Share Posted March 3, 2019 1 minute ago, rae houghton said: If you have time to post pics, would love to see them. I suppose when a person pulls out a tranny, and puts it back, or replaces it, the seals should always be replaced???? This is a real question to anyone caring to answer. Depends on how they’re looking before you put the new gearbox in - or if you want to do them it’s the best time with the box out. Also remember to replace the massive O ring on each side. This is the seal for the threads on the bearing carriers. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
rae houghton Posted March 3, 2019 Share Posted March 3, 2019 Thanks Bennie, If a person was storing the tranny for later use, what would be the best way to keep it intact , .....should one leave tranny gear oil in place? Cover openings with what plastic bags. stuff a sock in? suggestions. remove gear oil and replace when planning to reuse tranny turn gears manually every so often? thanks Quote Link to comment Share on other sites More sharing options...
el_freddo Posted March 3, 2019 Share Posted March 3, 2019 I’d keep the oil in the box and keep it away from the weather and moisture if possible. I like to store them under my bench off the floor if possible. Otherwise on a block of wood or two on the cement slap (floor) out of the way is the go. You can cover up any openings to reduce the risk of dust getting in. The sun might perish the seals, but it’s take a number of years in a shed. Left out in the Aussie summer sun it could take a year or two to kill the shaft seals Cheers Bennie Quote Link to comment Share on other sites More sharing options...
rae houghton Posted March 3, 2019 Share Posted March 3, 2019 Right....yes it will also be in the garage here. .... Yes the sun (and the salt air) here is hard on cars. Thanks for your reply Rae Quote Link to comment Share on other sites More sharing options...
rae houghton Posted March 3, 2019 Share Posted March 3, 2019 And thanks again DaveT Quote Link to comment Share on other sites More sharing options...
