I think that the block itself is pretty much the same for quite a few years and they are quite interchangeable.  If my memory serves me, this has been hashed out well in the past and if you search out swaps on this site, I am pretty sure is already out there.  The intake and heads will will vary  year by year and whether the heads need to be egr come into play  as well.   If you are looking for a more specific answer, it would be best if you  had a bit more specific question.
Block will bolt to all sorts of heads in the EJ range. It all comes down to the piston combination used with which head etc.
It will physically bolt into any EJ engine bay and as Crazyeights mentioned, it can be fitted into the EA series vehicles too with a bit of work.
You need to charenwith is what you’re trying to achieve and we can go from there ;)
Cheers
Bennie
