jono Posted December 31, 2018 Share Posted December 31, 2018 P437 3-M09 Exhaust system for turbo Item # 26 Exhaust pipe f assembly 44101GA130 85&86 all three holes about 35mm inside diameter. No O2 sensor hole 44101GA160 87 onwards Hole under turbo ranges 40 & 41 mm I unknowingly once fitted the 160 to what had the 130 smaller diameter. It sort of flew to 6500 in no time at all which wasn't too bad, but I was used to riding the torque curve with a little more control over a little more time. Was happier to return to smaller diameter Now recall my 87 AWD Vort also sports the smaller diameter so parts manual may not reflect actual in all markets. The 160 larger orifice pipes also sport an O2 sensor port and sensor What models had sensor here? About to swap in one of thescan't quite decide and cant Link to comment Share on other sites More sharing options...
jono Posted December 31, 2018 Author Share Posted December 31, 2018 Got a Gremlin Cant quite decide Maybe the big Zinger? Link to comment Share on other sites More sharing options...
jono Posted December 31, 2018 Author Share Posted December 31, 2018 Flippin' heck ! 20 different exh pipe centre assy's (rssentiessentially the cat) 20 ??!! Link to comment Share on other sites More sharing options...
el_freddo Posted December 31, 2018 Share Posted December 31, 2018 You already had a few New Years drinks Jono?? Happy New Year mate! Bottoms up! Bennie 1 Link to comment Share on other sites More sharing options...
jono Posted January 1, 2019 Author Share Posted January 1, 2019 Thanks mate but not before host site homeland hits it eh? I have this gremlin that starts ifI allow auto correctcorrect Look! See? I use auto correct option sometimes doubles up and cursor jumps back or forth Link to comment Share on other sites More sharing options...
jono Posted January 1, 2019 Author Share Posted January 1, 2019 Come inside for a break while spilled coolant dries up to allow me to crawl about under ute without getting too wet. I hate the taste of coolant Link to comment Share on other sites More sharing options...
jono Posted January 1, 2019 Author Share Posted January 1, 2019 H.m.mm found I have the zinger 41 mm outlet on my abortion of a crossover pipe I wonder if the underside of the turbo is size matched between the two generations? The awd might dull the response of the larger bore zinger pipe because this engine does not rev out too easily like my other one did in my part time 4wd GLTA. I hated it. Was too quick. This might explain 130 in third the other day when dealingpass hole - I liked it then ! It has been pointed out to me that the later turbo also had solenoid control on the wadwaste gate. I don't have any controller on the waste gate though this engine likely did in its original body. I think for differences sake the smaller 1985 style 36 mm orifice cross over needs to go in. Done. Decided. Now for some action Link to comment Share on other sites More sharing options...
jono Posted January 6, 2019 Author Share Posted January 6, 2019 Taken a few miles to get used to driving on the smaller bore up pipe. Now the power is there on tap at low revs not further up the rev range. Has made it much more tractable to drive. Somehow the loud pedal feels like it isharder to press. Theexhaust note from 2.5" system sounds tougher down low and she pulls out of corners better due to torque coming down the rev range a lot. Quite hard to make it do 80 klh in second now as job is done in power delivery by 65 Happy Link to comment Share on other sites More sharing options...
el_freddo Posted January 6, 2019 Share Posted January 6, 2019 Sounds good mate. I dunno why ppl want max boost so far up the rev range... I’m glad it all worked out for you! Cheers Bennie Link to comment Share on other sites More sharing options...
ausubaru92 Posted January 16, 2019 Share Posted January 16, 2019 On 1/1/2019 at 4:58 AM, jono said: It has been pointed out to me that the later turbo also had solenoid control on the wadwaste gate. I don't have any controller on the waste gate though this engine likely did in its original body. Expand On Series 2 cars with the hotwire MAF, the solenoid controlled boost pressure. It was basically an altitude compressor and increased boost pressure a little at higher altitudes when the ECU detected the MAF voltage was lower than it expected for a given RPM/throttle position On 1/1/2019 at 4:58 AM, jono said: I hated it. Was too quick. Expand Said no-one ever Link to comment Share on other sites More sharing options...
Steptoe Posted January 17, 2019 Share Posted January 17, 2019 Tambox reckons the ECU and sole Noida control gives the driver the best of both worlds with the larger bore up pipe Link to comment Share on other sites More sharing options...
Steptoe Posted January 17, 2019 Share Posted January 17, 2019 Timing now set to factory instead of possibly 30° btdc ( was off the scaled marks by long shot) small bore up pipe and twin core EA81 radiator in front the EA82T took it up a mountain test drive in rediculous heat twin fans on, heater blowing hot and she ran at 87°C , eight better than when she was in the donor GLTA happy Link to comment Share on other sites More sharing options...
el_freddo Posted January 17, 2019 Share Posted January 17, 2019 Turn the heater off and see what the difference is! You’ll melt your dashboard doing this with the heater on! Cheers Bennie Link to comment Share on other sites More sharing options...
Steptoe Posted January 17, 2019 Share Posted January 17, 2019 Not at 87° ! Link to comment Share on other sites More sharing options...
