dburton97128 Posted January 11, 2019 Share Posted January 11, 2019 Supposedly this bolt (long one at the bottom of the rear hub/shock housing) is supposed to be torqued with the wheels on and loaded with the vehicle weight. With the wheels on I see no possible way to get a torque wrench on either end of that bolt. Best I can get is a large crescent or open/box end wrench. I figure I would need to be able to pull about 150 lbs on that wrench to get to 103 ftlb. Not sure I can manage that. How do you do this properly? I could remove the wheels and bolt up the discs and lower the car down onto a block of wood, but don't want to over stress the discs by doing that. This bolt was out for removing axles to do rear wheel bearings. 2006 2.5i Thanks. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 11, 2019 Share Posted January 11, 2019 when I had to do something similar, I used a hydraulic jack to lift the wheel/hub/w'ever, to take 99% of the weight off that jack stand. be careful regardless of how you do it! 1 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 12, 2019 Share Posted January 12, 2019 (edited) Use the donut spare. Flip it around backwards if you need to. Drop or drive it on set of ramps. GD Edited January 12, 2019 by GeneralDisorder 1 Link to comment Share on other sites More sharing options...
dburton97128 Posted January 12, 2019 Author Share Posted January 12, 2019 I bolted the rotor down and lowered the pbrake drum portion down on a wood block and that worked fine. You could bolt an old rotor on upside down to lower on to if you feel more comfortable not putting pressure on the installed rotor. Also if you have an old steel rim wheel you could bolt it on upside down as well. If a tire is mounted it may not clear the fender though. It seems I was able to get about 70 ft lb on the bolts with the crescent wrench and tire on, so that probably would have held it in place well enough for completing the tightening with the wheel off. Link to comment Share on other sites More sharing options...
dburton97128 Posted January 12, 2019 Author Share Posted January 12, 2019 12 hours ago, GeneralDisorder said: Use the donut spare. Flip it around backwards if you need to. Drop or drive it on set of ramps. GD Oh, just saw that post. Best idea yet. Link to comment Share on other sites More sharing options...
