impreza ts problem
hi i have a problem whit my impreza its a ts wagon 2004 i replace the transmission because when i go at 45 miles the car make a noise an move to the right i open my transsmision and the shaft pinion was broken i buy a new trans and start making the same noise if i remove the fwd fuse works fine do you think guys maybe my rear differential its bad any idea
It's an automatic and you keep the FWD drive fuse installed? Are all 4 tires identical? Same Brand and Model?
In a new thread, ask for a shop recommendation in San Diego - maybe someone can send you to a subaru-friendly mechanic that can test drive it for you.
is the car new to you? how many miles? any wrecks or work done? Have you checked the brakes? especially the caliper on the right side - if it is sticking, it might cause the car to pull to that side.
I'd be surprised if the rear diff is involved but - you could have more than one problem.
Edited by 1 Lucky Texan
