cap86 Posted February 8, 2019 Share Posted February 8, 2019 Alt light comes on 1 minute after starting a cold engine. When the engine warms up to operating temp the light goes out and it charges. The speedometer jumps around while alt light is on then settles down rock solid when the light goes out. One cold morning I heated up the alternator (heat gun) and the alt light did not come on at all, it charged normally from cold start. Is this just a bad alternator (it's new) or could there be something besides the alternator causing this.,? Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 8, 2019 Share Posted February 8, 2019 any odd sounds when the light is on? it does seem like you've found the problem but, I think I'd want to check at the battery with a voltmeter, check the belt and maybe check the crank pulley for slippage. (it's 2 piece and can delaminate) Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 8, 2019 Share Posted February 8, 2019 Alternator is junk. Get one from Subaru. The reman alts for those cars are like $80 from Subaru. GD 1 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted February 8, 2019 Share Posted February 8, 2019 35 minutes ago, cap86 said: alternator (it's new) aftermarket alternators, starters, and fuel pumps are typically trash, i avoid them at all costs. so it's the opposite what you'd think - "new" probably means that is your problem. Subaru reman is $70 or so from the dealer. Go get one and return low grade aftermarket. Quote Link to comment Share on other sites More sharing options...
sparkyboy Posted February 9, 2019 Share Posted February 9, 2019 Has the exiter wire (12 v switched) been replaced or messed with recently? A screwy exiter will cause wonky readings at the battery. But yea as stated above, your alternator is suspect. Quote Link to comment Share on other sites More sharing options...
cap86 Posted February 9, 2019 Author Share Posted February 9, 2019 Thanks, all. No odd noises at all, I adjusted the belt to no avail. Jiggling/wiggling the alt wires has no effect and one morning I unplugged the wires and heated that plug separately - didn't make any difference. I think it's time to get a Subaru replacement alt. 1 Quote Link to comment Share on other sites More sharing options...
