Difference between Baja Turbo and non-turbo
catz - GD is right, most everything under the hood is quite a bit different and of course, different computer running everything. premium fuel needed too. about 90% of hood scoop air goes thru the intercooler, the rest is split and directed to turbo cooling.
check www.cars101.com for Subaru specs going back many years.
Edited by 1 Lucky Texan
  • Like 1
  • 2 weeks later...
They are the same displacement engine, and the same basic engine layout. But different in almost every detail.
Turbo is DOHC, non turbo is SOHC.
Turbo has a semi-closed deck block and lower compression. Non-turbo is open deck.
Yes, hood scoop feeds an intercooler.
Transmission is similar, but different. Gearing and AWD differences. Suspension is similar, but stiffer, etc.
