ECS Light
  On 2/13/2019 at 6:38 PM, Dinky26 said:
I’m no longer driving the car due to my having a stroke, my brother is driving it to work now. So this problem is kinda second hand.
What is the ECS Light connected to or monitoring? On a 1986 Brat.
Expand
Nothing.  It's unused on 4wd models (which all brats are)
Is it on?
2wd wagons/sedans, etc..had "feedback" carb, which could vary air bleed to adjust mixture based on O2 sensor.  I don't think Brats ever got that setup MAYBE in California?
Is it on?
Expand
Like I had noted in the original post, it is a 1986 Brat, it’s okay sometimes we all read over stuff.
It’s just weird that it came on last night on his way home. It’s also from CA originally.
It also has a Weber carburetor on it too.
Edited by Dinky26
To add carburetor.
Expand
If it has a Weber then the computer and ECS light are doing nothing.  Pull the bulb.
  On 2/15/2019 at 8:39 AM, pksjeep said:
I also have an 86 Brat. I have not seen the light yet. Can you tell me how to reset it?
Paul
Expand
There's three connectors under the dash - you unplug the pair that's plugged in, and connect the one that was free to it's mate from the pair. This resets the light for another 60k - then you swap them back again. You repeat every 60k. It's a reminder to clean the EGR. It's in the service manual.
Edited by GeneralDisorder
  • Like 1
