Olyroller83GL Posted February 15, 2019 Share Posted February 15, 2019 I installed a new Spanish Webber on my 83 GL two years ago and it ran great for a while. But around 6 months ago it started stalling when I turn left with the clutch pushed in. I recently put in a fuel pressure reg when it started flooding but I am still having the same problem. Any help would be greatly appreciated. Thanks. Link to comment Share on other sites More sharing options...
naru2 Posted February 16, 2019 Share Posted February 16, 2019 You need to adjust he float. Link to comment Share on other sites More sharing options...
Olyroller83GL Posted February 16, 2019 Author Share Posted February 16, 2019 The installation guide from Weber said it came set at the right level from the factory But I suppose I should crack into it and check. Anything else I should look at while I got it split in half? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 16, 2019 Share Posted February 16, 2019 It does sound like the float needs adjustment - but also check your fuel pressure. With a gauge. GD Link to comment Share on other sites More sharing options...
naru2 Posted February 16, 2019 Share Posted February 16, 2019 (edited) Check float buoyancy(no holes/fuel absorption) and alignment(no rubbing) Inspect and clean the needle and seat. Check the float drop while you are there. Some floats need periodic adjustment.IME. Edited February 18, 2019 by naru2 Link to comment Share on other sites More sharing options...
