Is there a formula to use for a 3” lift when i extend the strut bottom to drill the bottom hole to maintain the stock camber the picture is for a buick the bottom hole is new the top two are stock and are inline with each other it looks like the bottom one is drilled at a offset any help would be great.
43 minutes ago, FerGloyale said:
You're going to need wheel spacers if you do that route.  The tire/rim will hit that strut if you don't space it down.
Talk to Anderson design lifts......his rears are like that.
Most people use strut top lifts.
I dont see wheel spacers in the kit they offer so i emailed them
