1997reduxe Posted February 20, 2019 Share Posted February 20, 2019 Hi all. im trying to take out my clutch cable on my 95 legacy 5mt. Where it attaches under the dash, I got the end of the cable off the hook it goes up to, but do you need to take off the pedal to get the sliver sleeve part around the rubber hose, out of that squarish metal thing it sits in? or should it just pull out? thanks so much ’97 Link to comment Share on other sites More sharing options...
lmdew Posted February 26, 2019 Share Posted February 26, 2019 Have to remove the clip off the pin, push the plastic tabs in on the end of the pin, then remove the metal pin going through square bracket attached to the pedal. Link to comment Share on other sites More sharing options...
