YaBoyKingsley Posted February 26, 2019 Share Posted February 26, 2019 Okay so I have quite a few spare ea71s for my 78 sema brat project and someone used the oil pan as a jack point and then only changed the oil pan and if that wasn’t bad enough the oil pick up tube got bent and someone tried to pry it out with a screwdriver and I tried to gently get it out and it’s starting to tear at the insert point it’s about halfway out but I’m afraid it might be beyond saving so my questions are do I separate the tube from the insert then try to pull the insert out separately and tig weld it back together later? and does anyone have a spare? thanks for the help in advance Link to comment Share on other sites More sharing options...
