Rear wheel bearings ring nut tool
Too good to not share! Looked all over the forums and could not find where to buy a ring nut tool or easily make one.
The tool straight out of oreilly's :
Part number is W1271, probably sold at most oreilly's :
All you have to do is cut two of the tabs off like so :
Now you have a ring nut tool you can use with an impact!
There are 4 notches in the ring nut. Put the two prongs from the tool into the two smaller notches.
I was a bit scared that the two tabs would shear off. But after hitting it 3 minutes straight with an impact it held up fine. Sure beats using a chisel and a BFH to knock the ring nut out! Best part is that it was only $20 from my local oreilly's.
Edited by alexbuoy
  • Like 3
I made my own tool and it utilises all four slots in that nut device.
I use a large adjustable shifter on it without any issues.
Thereare pics of it floating around the interwebs. Too hard basket to find one on my phone atm.
Cheers
Bennie
  • Like 3
