97' Impreza Transmission Pan Broken Bolt
Hi all.  While removing the oil pan on my transmission to reseal I ended up snapping a bolt.  I drilled it out but for some reason I cannot tap the hole.  I'm using a new tap so its sharp but it won't cut any threads.
Any ideas on what I can do?  Thanks
it just sits in there spring loaded.  the tension is enough to keep it from backing out.  these aren't high torque bolts so that should be good enough
Edited by nvu
2 hours ago, palfer said:
I've not used helicoil before.  How does the insert anchor itself into the hole if there aren't threads?
Just to clarify, a helicoil is a coil of square wire.  You oversize drill and tap the damaged hole, then screw the helicoil into the new threads - that's what keeps it in place.  Then the inside of the coil is the new thread your fastener screws into.
That was my impression which is sort of the struggle because I can't tap the hole.  Seems the metal is so soft the hole just widens on me.  If I could tap it, I'd just drill out the hole in the pan and use a larger bolt.  Maybe I can get the coil to bite just enough to thread a bolt.  As mentioned, there is very little torque on these bolts, just need it flush to prevent a fluid leak
