palfer Posted March 11, 2019 Share Posted March 11, 2019 Hi all. While removing the oil pan on my transmission to reseal I ended up snapping a bolt. I drilled it out but for some reason I cannot tap the hole. I'm using a new tap so its sharp but it won't cut any threads. Any ideas on what I can do? Thanks Link to comment Share on other sites More sharing options...
FerGloyale Posted March 11, 2019 Share Posted March 11, 2019 Looks like you drilled it out too big to make threads. Might need to helicoil that m6 X1.00 threads Link to comment Share on other sites More sharing options...
palfer Posted March 11, 2019 Author Share Posted March 11, 2019 I've not used helicoil before. How does the insert anchor itself into the hole if there aren't threads? Link to comment Share on other sites More sharing options...
nvu Posted March 11, 2019 Share Posted March 11, 2019 (edited) it just sits in there spring loaded. the tension is enough to keep it from backing out. these aren't high torque bolts so that should be good enough Edited March 11, 2019 by nvu Link to comment Share on other sites More sharing options...
palfer Posted March 11, 2019 Author Share Posted March 11, 2019 Got it. I just hope I can find a coil big enough for the hole. Link to comment Share on other sites More sharing options...
jonathan909 Posted March 11, 2019 Share Posted March 11, 2019 2 hours ago, palfer said: I've not used helicoil before. How does the insert anchor itself into the hole if there aren't threads? Just to clarify, a helicoil is a coil of square wire. You oversize drill and tap the damaged hole, then screw the helicoil into the new threads - that's what keeps it in place. Then the inside of the coil is the new thread your fastener screws into. Link to comment Share on other sites More sharing options...
palfer Posted March 11, 2019 Author Share Posted March 11, 2019 That was my impression which is sort of the struggle because I can't tap the hole. Seems the metal is so soft the hole just widens on me. If I could tap it, I'd just drill out the hole in the pan and use a larger bolt. Maybe I can get the coil to bite just enough to thread a bolt. As mentioned, there is very little torque on these bolts, just need it flush to prevent a fluid leak Link to comment Share on other sites More sharing options...
jonathan909 Posted March 12, 2019 Share Posted March 12, 2019 It's just an aluminum casting - shouldn't be that hard to tap - but you're going to have to use a bottom tap, otherwise a through-hole tap taper is probably going to just chew up the hole. Link to comment Share on other sites More sharing options...
palfer Posted March 12, 2019 Author Share Posted March 12, 2019 Good to know. my taps are all tapered at the end and that is exactly what is happening.. Wasn't aware there were variations. The bottom tap has no taper so it cuts right away? Link to comment Share on other sites More sharing options...
jonathan909 Posted March 12, 2019 Share Posted March 12, 2019 A very slight taper right at the tip (which is flat so it can tap all the way to the bottom of the hole, unlike the usual pointy tapered taps) just to get it started. Link to comment Share on other sites More sharing options...
