nipper Posted March 21, 2019 Share Posted March 21, 2019 Do all crosstreks seem to have a problem with pre-mature wheel bearing failure? s there a fix for it? Link to comment Share on other sites More sharing options...
idosubaru Posted March 21, 2019 Share Posted March 21, 2019 i don't think so - don't seem any more prone than anything else. how many have you seen - all on the same vehicle? Link to comment Share on other sites More sharing options...
nipper Posted March 21, 2019 Author Share Posted March 21, 2019 I have a freind with a crosstek that roars. He called the dealership and they said "It's probably wheel bearings we see a lot of them". Hes got only 57K on the car. Doing a google search its not red flagged, but it does seem they are failing between 50-60K if they fail. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 21, 2019 Share Posted March 21, 2019 my WRX had a bad rear bearing - under 60K miles. Link to comment Share on other sites More sharing options...
idosubaru Posted March 21, 2019 Share Posted March 21, 2019 On 3/21/2019 at 2:53 AM, nipper said: I have a freind with a crosstek that roars. He called the dealership and they said "It's probably wheel bearings we see a lot of them". Hes got only 57K on the car. Doing a google search its not red flagged, but it does seem they are failing between 50-60K if they fail. Expand Got it - a higher bearing failure ***rate*** is the new norm for *a wide range* of vehicles, not just crosstek's or Subaru's. Plenty still make 150,000 miles without issues, but it's no surprise to see a few early failures like this. For illustration purposes only, these numbers are inaccurate, but 20 years ago let's say early bearing failure happened 5% of the time, now it's 15%. That would mean it's a crazy high 300% failure rate increase but plenty still never see issues either. 1 Link to comment Share on other sites More sharing options...
nipper Posted March 21, 2019 Author Share Posted March 21, 2019 Another reason to keep my 2005 Outback 1 1 Link to comment Share on other sites More sharing options...
idosubaru Posted March 21, 2019 Share Posted March 21, 2019 On 3/21/2019 at 5:46 PM, nipper said: Another reason to keep my 2005 Outback Expand I'm not sure - but if I had to guess I'd guess the 2005's also have a higher failure rate of wheel bearings. i don't see enough Subaru's to know, but all things being equal (which is nearly impossible now due to age/miles of older stuff) but i'd guess like somewhere in the 90's and earlier fail less often at lower miles than late 90's until now. 2 Link to comment Share on other sites More sharing options...
ezapar Posted March 21, 2019 Share Posted March 21, 2019 Yep. ALL Crosstreks blow their wheel bearings at right about 21,345 miles. lol Keep your 2005 car. lol Link to comment Share on other sites More sharing options...
rustfarmer Posted October 6, 2019 Share Posted October 6, 2019 Our 2013 needed both rears at 90K. Dealer charged $1200, but at least they changed one again 20K later when it failed too without charge. I am used to my older cars getting 300K from rear bearings. Link to comment Share on other sites More sharing options...
idosubaru Posted October 6, 2019 Share Posted October 6, 2019 On 10/6/2019 at 7:32 PM, rustfarmer said: Our 2013 needed both rears at 90K. Dealer charged $1200, but at least they changed one again 20K later when it failed too without charge. I am used to my older cars getting 300K from rear bearings. Expand There’s a significant chance only one bearing was bad. shops often quote or replace two bearings for a couple of reasons, when in reality it’s not necessary and only one side is bad. $1,200 is high. $200 parts, they finished in 2 hours. Most excellent independents should come in under $400 per hour. Link to comment Share on other sites More sharing options...
