rallyruss Posted July 2, 2004 Share Posted July 2, 2004 who has done the swap to the WRX TDO4 turbo? does any one have pics or thoughts on dificulty? I know the bolt patern is a little off no biggy I can weld. I know the down pipe from the wrx must be used. but what about the cooling and oil lines? any other interferance problems? what about the turbo inlet to maf? Link to comment Share on other sites More sharing options...
WJM Posted July 2, 2004 Share Posted July 2, 2004 SUBARUTex did that. Search for his thread on the RX build up of his... Link to comment Share on other sites More sharing options...
rallyruss Posted July 2, 2004 Author Share Posted July 2, 2004 thanks Will I looked at that. I see Tex appears to have bolted his directly to the up pipe where garner had to raise and tip the turbo a bit. I suppose the vehicle differance could be the reason. I wonder if tex found a elbow to use to the maf? I have not found any real final pics of either ones car once COMPLETELY done. I am curious. I need to get my car back up and running asap. Link to comment Share on other sites More sharing options...
