Starlite Posted April 7, 2019 Share Posted April 7, 2019 So i have change passenger front axle and got a vibration when in Drive or Reverse. Google it and found out it is a known problem with aftermarket shafts. But If i only change the outer joint Will i still get a vibration? Link to comment Share on other sites More sharing options...
el_freddo Posted April 7, 2019 Share Posted April 7, 2019 Possibly. Shafts you don’t suff around with. As soon as you find a split boot, change it! Replace shafts with genuine. As for replacing outter joint, it could be worth a try. I’m guessing this is the joint that went bad on the original shaft. Cheers Bennie Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted April 7, 2019 Share Posted April 7, 2019 cheaper to get an OEM used axle, check car-part.com Link to comment Share on other sites More sharing options...
