rverdoold Posted April 17, 2019 Share Posted April 17, 2019 My PowerSteering (PS) pump bearing showed signs of going bad with a ticking steel on steel noise especially in cold weather. Now I got one from a donor car but of course to the same model same engine number the pump is slightly different (only mine is 9 months newer). (mine is last BP 2009 OBW series EU). The main housing of the pump looks exactly the same. But then: 1. The one piece where the piping connects with the elbow has a different angle, pointing more forward. I was thing to just undo the screw and use the elbow one I have on car now. 2. The other piping connector is more a mystery, mine has the banjo bolt directly on the housing, but here seems a nut is there. Can i just remove that nut? and then put my current banjo on the housing. Or, do I have to put the banjo on top of this nut (seems to fit) Then the bracket that holds the cover is bend (donor had to hood damage, ran into a trailer after it was rear-ended), but can easily transfer my own as well. Will this work? Link to comment Share on other sites More sharing options...
FerGloyale Posted April 19, 2019 Share Posted April 19, 2019 I think banjo screws into that fitting. Link to comment Share on other sites More sharing options...
