Prwa101 Posted April 18, 2019 Share Posted April 18, 2019 All you guys who have been around for a while have seen my old work on the R160 ratchet locker. Sadly never got any further on it due to funding and machine limitations. But! ADF and Torqmasters has teamed up to make this happen! 400$ a unit roughly should be completed and may/June! Big news for almost all Subarus out there as the R160 was used thought the years. If any one has any questions let me know! Link to comment Share on other sites More sharing options...
carfreak85 Posted April 18, 2019 Share Posted April 18, 2019 Before folks get all hyped up on this, no, this is not a selectable air locker. This is a ratcheting differential, not viscous, not clutch type, not helical. Link to comment Share on other sites More sharing options...
Prwa101 Posted April 18, 2019 Author Share Posted April 18, 2019 On 4/18/2019 at 3:33 PM, carfreak85 said: Before folks get all hyped up on this, no, this is not a selectable air locker. This is a ratcheting differential, not viscous, not clutch type, not helical. Expand Spot on! ^ "Will this fit my Subaru?" As long as its not an STI lol R160 is in almost every Subaru out there Link to comment Share on other sites More sharing options...
Numbchux Posted April 18, 2019 Share Posted April 18, 2019 (edited) On 4/18/2019 at 3:33 PM, carfreak85 said: Before folks get all hyped up on this, no, this is not a selectable air locker. This is a ratcheting differential, not viscous, not clutch type, not helical. Expand Still worth getting hyped up for. I'll be buying one FOR SURE. There was mention in the Facebook post about 1-bolt and 5-bolt versions. Looks like these will drop into the factory carrier to replace the spider gears, so maybe there are 2 different versions. And I'm assuming it wouldn't work in place of a factory LSD. But these are all details. Edited April 18, 2019 by Numbchux Link to comment Share on other sites More sharing options...
Prwa101 Posted April 19, 2019 Author Share Posted April 19, 2019 On 4/18/2019 at 6:03 PM, Numbchux said: Still worth getting hyped up for. I'll be buying one FOR SURE. There was mention in the Facebook post about 1-bolt and 5-bolt versions. Looks like these will drop into the factory carrier to replace the spider gears, so maybe there are 2 different versions. And I'm assuming it wouldn't work in place of a factory LSD. But these are all details. Expand The difference there is the newer R160 and the older R160. Newer being the weird tribecas and ascents. Older being everything else. The vLSD housing didnt allow for enough room and has a different inner one spider dosnt come out like the others. 1 Link to comment Share on other sites More sharing options...
Numbchux Posted April 19, 2019 Share Posted April 19, 2019 On 4/19/2019 at 1:29 AM, Prwa101 said: The difference there is the newer R160 and the older R160. Newer being the weird tribecas and ascents. Older being everything else. The vLSD housing didnt allow for enough room and has a different inner one spider dosnt come out like the others. Expand Cool. Is the 5-bolt version any stronger? 1 Link to comment Share on other sites More sharing options...
Prwa101 Posted April 19, 2019 Author Share Posted April 19, 2019 On 4/19/2019 at 1:13 PM, Numbchux said: Cool. Is the 5-bolt version any stronger? Expand I think there pretty much the same just different gear ratios much higher than the older one 1 Link to comment Share on other sites More sharing options...
pontoontodd Posted May 21, 2019 Share Posted May 21, 2019 On 4/19/2019 at 8:38 PM, Prwa101 said: I think there pretty much the same just different gear ratios much higher than the older one Expand We're talking the Tribeca diff has one bolt side covers vs the more common five bolt side covers? Looks like Tribeca has 3.58 gear ratio. Link to comment Share on other sites More sharing options...
