Steptoe Posted April 21, 2019 Share Posted April 21, 2019 You can't build a house this level...only out 0.3° Link to comment Share on other sites More sharing options...
Steptoe Posted April 21, 2019 Author Share Posted April 21, 2019 I will blame the concrete for that small discrepancy 1 Link to comment Share on other sites More sharing options...
Steptoe Posted May 1, 2019 Author Share Posted May 1, 2019 Despite such an even keel ( floor is the same) I have eyebrow measures 10 mm lower on the drivers RHS ?? Link to comment Share on other sites More sharing options...
el_freddo Posted May 1, 2019 Share Posted May 1, 2019 Talking to yourself again Jono?? Must be something I have to look forward to with the difference front to rear, maybe your front bumper isn’t mounted properly - or you’ve got a twisted body, but I’d expect to see that show up in the rear end too. Cheers Bennie Link to comment Share on other sites More sharing options...
sparkyboy Posted May 2, 2019 Share Posted May 2, 2019 Ok this is not a smart as s comment but is the front 0.3 degrees level as well? 10mm is so small pump the tire up more, let some out the other side? Failing that bust out with a spacer or shim for the strut mount? Getting ready for an upcoming show? cheers man Link to comment Share on other sites More sharing options...
