old sub freak Posted April 25, 2019 Share Posted April 25, 2019 (edited) Hey gang..So I just got a 84 brat running after sitting 6 years? well I got it running but instead of purring it is ROARING !! I can't get it to idle down.The cable is loose so its something to do with the carb? I think ?? I'm going to check the power to the different wires on the carb and see if that might be it ..Any thoughts ?/ Thanks PS..If i pull one of the spring loaded piston things it will come down some...but still..its a ha toch ee Edited April 25, 2019 by old sub freak Link to comment Share on other sites More sharing options...
czny Posted April 25, 2019 Share Posted April 25, 2019 Is the throttle return spring intact & in its place? Something allowing the throttle butterfly to move freely? Link to comment Share on other sites More sharing options...
DaveT Posted April 25, 2019 Share Posted April 25, 2019 Check that the throttle shaft turns freely. Heck that the fast idle cam and choke linkages are all moving correctly. The only wires should be a solenoid to shut off the fuel to prevent diesel ing when shut off, and the choke heater, which is supposed to gradually open the choke. Link to comment Share on other sites More sharing options...
moosens Posted April 25, 2019 Share Posted April 25, 2019 There’s another issue that applies as well. The black plastic flying saucer/hat looking part upstream of the carburetor breaks apart and small pieces of the plastic end up in the carb. This caused one longtime board member to have a wide open throttle driving my former 86 Brat back after I sold it to him. It really happened. Good luck , let us know what you found. Link to comment Share on other sites More sharing options...
old sub freak Posted April 25, 2019 Author Share Posted April 25, 2019 Well....Easy peasy Japanesy I sprayed down all the linkage with PB Blaster...Ta Da Fixed it haha ,Yep just stuck linkage ..Got it to idle nice and on with the program...Its been through the mill BUT its a runner !! Thanks for the help !! Link to comment Share on other sites More sharing options...
czny Posted April 25, 2019 Share Posted April 25, 2019 On 4/25/2019 at 5:15 PM, old sub freak said: Well....Easy peasy Japanesy I sprayed down all the linkage with PB Blaster...Ta Da Fixed it haha ,Yep just stuck linkage ..Got it to idle nice and on with the program...Its been through the mill BUT its a runner !! Thanks for the help !! Expand Must've been fuel varnish from sitting so long. Link to comment Share on other sites More sharing options...
sparkyboy Posted April 25, 2019 Share Posted April 25, 2019 (edited) Pb blast is great, but it's a penetrating oil not really a lubricant so use it to free up stuck parts, clean with a wire brush a soft one like the brass colored wire or a stiff nylon brush. Then use brake cleaner and compressed air then use bike chain lube or white lithium is meant for metal on metal. That's just what I would do, and you're probably way ahead of me judging by the ride you have. pb if not wiped off attracts dirt and I think corrodes steel eventually. Cheers on the easy fix though! Now to drive her like you stolded her! Edited April 25, 2019 by sparkyboy Link to comment Share on other sites More sharing options...
88SubGL Posted April 26, 2019 Share Posted April 26, 2019 Any type of wet lube attracts dirt. Like wd-40, chain lube, grease, etc. That’s what carb cleaner is for, to get rid of the garbage that is preventing the linkage from moving freely. If it has a cable going to the carb it could be frayed inside the cable housing and not allowing it to idle back down. I had that happen on a Datsun pickup. Link to comment Share on other sites More sharing options...
sparkyboy Posted April 27, 2019 Share Posted April 27, 2019 ^^ right, that's why I love this stuff! Link to comment Share on other sites More sharing options...
