steve56 Posted May 3, 2019 Share Posted May 3, 2019 Have 01 Legacy. Make clicking noise when shifting from park to reverse. Trying to understand what the noise is. Link to comment Share on other sites More sharing options...
3Pin Posted May 3, 2019 Share Posted May 3, 2019 automatic or manual? Link to comment Share on other sites More sharing options...
steve56 Posted May 3, 2019 Author Share Posted May 3, 2019 Auto. Link to comment Share on other sites More sharing options...
FerGloyale Posted May 4, 2019 Share Posted May 4, 2019 are you hearing the shift lock solenoid? Or the Lock cylinder solenoid? Both activate during the shift from P to R or D. Link to comment Share on other sites More sharing options...
steve56 Posted May 4, 2019 Author Share Posted May 4, 2019 14 hours ago, FerGloyale said: are you hearing the shift lock solenoid? Or the Lock cylinder solenoid? Both activate during the shift from P to R or D. Could you give me some more detail as to where these two solenoids are located. Link to comment Share on other sites More sharing options...
FerGloyale Posted May 4, 2019 Share Posted May 4, 2019 one is in the column attached to the lock cyl. This one keep you from turning key all the way to "off" unless the shifter is in P The other one is under the shifter. it has to unlatch in order to shift out of P into a gear. It unlocks when the brake is depressed. Link to comment Share on other sites More sharing options...
CNY_Dave Posted May 7, 2019 Share Posted May 7, 2019 It could even be a front ball joint, that was my first clue one was shot. Link to comment Share on other sites More sharing options...
