moosens Posted May 5, 2019 Share Posted May 5, 2019 92 front wheel drive Legacy right rear caliper top stud is moving , as in its loose but I can’t seem to get a good enough grip on the stud to then try to loosen the caliper off of it. So when I pivoted the caliper upward the stud was turning itself out and no matter what I did I couldn’t get the caliper to slide off the stud. It was getting dark and I just had to leave it. I’m sure I’ll get it freed up but just had to vent and see who says what for advice. I used propane flame and a 2 lb hammer but I’m afraid I’m going to destroy the caliper casting. Its at a point that I can’t slide it off nor can I return it to a position that allows the caliper to seat back down with new pads. I really just want it off entirely now so I can remove the rust , get a new stud , and who knows what else. The whole job went up and down but success was had and it was wrap up time. Don’t you know this had to happen. Replaced bearing and parking shoes firstly the saw I had fresh pads in stock. I did soak it with PB Blaster before I left it for the night. Link to comment Share on other sites More sharing options...
Crazyeights Posted May 5, 2019 Share Posted May 5, 2019 So, did you get this resolved? Link to comment Share on other sites More sharing options...
lmdew Posted May 5, 2019 Share Posted May 5, 2019 Pull the 2 14mm bolts holding the caliper bracket on and just replace the complete thing. I might have one, but I'm out of town for the week. Larry Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 5, 2019 Share Posted May 5, 2019 Yeah - usually this means the whole mess goes in the f*ckit bucket. GD 1 Link to comment Share on other sites More sharing options...
montana tom Posted May 5, 2019 Share Posted May 5, 2019 Or to Rock auto as a core return... Link to comment Share on other sites More sharing options...
moosens Posted May 5, 2019 Author Share Posted May 5, 2019 Ahh lovely. Rain now too. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 5, 2019 Share Posted May 5, 2019 A lot of that stuff on rockauto is closeout so they don't even want a core. You can also easily upgrade to newer model rear discs. Like a 97 Outback, etc. The rears don't have the wheel clearance requirements like the fronts do and all the parking brake stuff should be the same. GD Link to comment Share on other sites More sharing options...
idosubaru Posted May 5, 2019 Share Posted May 5, 2019 If oxy torch isnt an option Hammer and large chisel in exact direction it needs to move and it’ll come off without compromising damage if it’s now moving. The ones that don’t move at all until WAILING a few dozens times are the ones that start getting damaged. Ive mangled a few of those pins good but always reusable. Work it back and forth rotating and pounding it out and it’ll come I guarantee it. Just keep at it. Link to comment Share on other sites More sharing options...
moosens Posted May 6, 2019 Author Share Posted May 6, 2019 Rain delay. Should be back at it later today. I took the whole bracket off. Had to relocate the car so I clamped the piston and didn’t hit the brakes anyways - blessed are the manual shifts in times like this!! First order will be disconnecting the line and getting the unit to a workable place , and maybe heat and beat. Although when I saw what I’d done already in daylight I’ve peen’d the casting over at the stud trying to beat it back on. So I’ll be shopping for a caliper and stud. Link to comment Share on other sites More sharing options...
moosens Posted May 6, 2019 Author Share Posted May 6, 2019 Easy enough in the end. Went to Autopart International as they’ve been very reliable with having items in stock. Pay a little more but I never have any problems. Hillbilly bleed of the brakes using a 2x2 of a particular length and the drivers seat. Works , done it several times. When you’re alone and don’t have the bleeder tool you improvise. Nice parking brake once again. Good pedal action , all back to normal. 2 Link to comment Share on other sites More sharing options...
idosubaru Posted May 7, 2019 Share Posted May 7, 2019 Excellent Link to comment Share on other sites More sharing options...
