Tswami Posted May 12, 2019 Share Posted May 12, 2019 I was doing some maintenance to a recently purchased loyale and pulled the throttle body off to clean and check the throttle position sensor. Put it back together and now it's pouring white smoke out the exhaust. I did not change any gaskets, is it possible that coolant is leaking into the intake from this? I didn't think I saw any coolant lines going to the intake there but maybe I screwed up. Link to comment Share on other sites More sharing options...
DaveT Posted May 12, 2019 Share Posted May 12, 2019 Yes, there is a coolant passage in the manifold, directly under the throttle body. There is a special oem o ring that seals it. Link to comment Share on other sites More sharing options...
Steptoe Posted May 13, 2019 Share Posted May 13, 2019 Sounds like spfi Link to comment Share on other sites More sharing options...
FerGloyale Posted May 15, 2019 Share Posted May 15, 2019 you need a toilet bowl gasket! 1 Link to comment Share on other sites More sharing options...
