Unknownjeremiah Posted May 21, 2019 Share Posted May 21, 2019 (edited) So my cooling fan died. It’s an old metal housed one with a 4 blade fan. What would be a good replacement without going through the core to mount it? Thanks. Edited May 21, 2019 by Unknownjeremiah I’m a dumbass Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 21, 2019 Share Posted May 21, 2019 Used factory. If you can find one. Next best bet is to get an early legacy fan and cut/weld the mounting for the motor into the EA fan shroud. Have done this - works great. Fabrication skill required. Aftermarket fans (especially cheap ones) completely suck and are for suckers. GD 2 Quote Link to comment Share on other sites More sharing options...
Unknownjeremiah Posted May 21, 2019 Author Share Posted May 21, 2019 Ok. Thanks. I’ll try to find a used factory one. Quote Link to comment Share on other sites More sharing options...
Unknownjeremiah Posted May 30, 2019 Author Share Posted May 30, 2019 So, still have no luck making it to grab my fan off my brat. Might just bite the bullet and get this motor off the Subaru page Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 2, 2019 Share Posted June 2, 2019 That's for an EA82. Wrong motor. The EA81 motor is long time NLA. GD Quote Link to comment Share on other sites More sharing options...
bratman2 Posted June 2, 2019 Share Posted June 2, 2019 I got spares for an EA81. Sadly on opposite coast so pretty expensive to ship. Quote Link to comment Share on other sites More sharing options...
FerGloyale Posted June 2, 2019 Share Posted June 2, 2019 (edited) I use aftermarket a 10" and a 12" toghether on an Stock EA81 radiator cooling the EJ22 in my wheeler. If you buy 2 good quality aftermarket fans, it will work fine. $40-65 each...........from Napa, not $10 ebay fans. But DO NOT use the stupid pull through mounting plastic tabs. These put the fan right against the radiator and vibrations will cause the fan to rub intot he soft brass radiator and make a hole. Or they will break, because they are cheap plastic tabs. take time to build a metal frame that bolts into the OE mounting holes. 1/4" bolt heads slip nicely into the mounting slots. Those bolts can then either be welded or threaded into a piece of angle iron top and bottom. then that angle bolted to the radiator face's OE holes. Edited June 2, 2019 by FerGloyale 1 Quote Link to comment Share on other sites More sharing options...
Unknownjeremiah Posted June 2, 2019 Author Share Posted June 2, 2019 3 hours ago, bratman2 said: I got spares for an EA81. Sadly on opposite coast so pretty expensive to ship. I was about to spend too much on the wrong one, my zip is 97501. I’m down to just get a working, fitting one. Quote Link to comment Share on other sites More sharing options...
sparkyboy Posted June 2, 2019 Share Posted June 2, 2019 The ea81 fan is smaller than ea82? I ask because the biggest flat rate box is $17 to ship I can see how an ea82 fan fits... I placed a reader for a mechanical temp gauge where the plastic plug goes for ea82 radiator and for a long time I just air flow cool my car. It's fine for the street so I would do that until your fan situation is in order. It is a bummer cause you can't go off roading. Quote Link to comment Share on other sites More sharing options...
naru2 Posted June 2, 2019 Share Posted June 2, 2019 1981 Cooling Fan Assembly (Rad and Con mtd.) Subaru Passenger Car Mitsu-RH A CORE $35 East Coast Auto Source VARA USA-VA(Moneta) Request_Quote 1-800-869-0655 Request_Insurance_Quote 1982 Cooling Fan Assembly (Rad and Con mtd.) Subaru GL 73364 $30 Lowell Used Auto Parts USA-MA(Lowell) Request_Quote 800-952-9775 / 978-454-4444 Request_Insurance_Quote 1983 Cooling Fan Assembly (Rad and Con mtd.) Subaru 4-BLADE STOCK# #DP29018 DP29018 $30 Sibum's Auto Parts, Inc. USA-PA(East-Stroudsburg) Request_Quote 1-570-421-3086 Request_Insurance_Quote 1984 Cooling Fan Assembly (Rad and Con mtd.) Subaru 3-97,COMPLETE A 14505 $30 Langston's Used Auto Parts USA-FL(Tampa) Request_Quote 1-813-988-7341 Request_Insurance_Quote 1983 Cooling Fan Assembly (Rad and Con mtd.) Subaru Brat MITSUBA TAG46949 674BRA $Call Southern Tier Auto Recycling USA-NY(Beaver-Dams) Request_Quote 1-800-640-7995 Request_Insurance_Quote 1985 Cooling Fan Assembly (Rad and Con mtd.) Subaru Brat Mistuba, sell as assym A 12314 $Call Central Florida Auto Salvage USA-FL(Zephyrhills) Request_Quote 1-813-782-4805 1-800-380-5150 Request_Insurance_Quote 1982 Cooling Fan Assembly (Rad and Con mtd.) Subaru Brat MITS ON RT SIDE IN VEHICLE, TAG# #6741548, YELLOW-TAN 821548 $Call Roger's Auto Sales & Used Part USA-VA(New-Market) Request_Quote 540-740-8733 / 800-377-8302 Request_Insurance_Quote 1987 Cooling Fan Assembly (Rad and Con mtd.) Subaru 099151 $Call Best Auto and Used Parts USA-GA(Palmetto) Request_Quote 770-306-9000 Request_Insurance_Quote 1982 Cooling Fan Assembly (Rad and Con mtd.) Subaru GL 4 CYL,FWD,Factory a00656 $Call For Less Used Auto Parts USA-TX(Houston) Request_Quote 713-734-1621 Request_Insurance_Quote Year Part Model Description Part Grade Stock# US Price Dealer Info Quote Link to comment Share on other sites More sharing options...
naru2 Posted June 2, 2019 Share Posted June 2, 2019 1983 Cooling Fan Assembly (Rad and Con mtd.) Subaru rad, Hitachi- A 11274 $35 Chase Auto Parts USA-IA(Waterloo) Request_Quote 1-800-728-2568 Request_Insurance_Quote 1985 Cooling Fan Assembly (Rad and Con mtd.) Subaru 2HB,1.8,NAC.CHK-ID A 4A0236 $25 A-Burlington Used Auto Parts USA-MA(Shirley) Request_Quote 1-800-228-5544 Request_Insurance_Quote 1983 Cooling Fan Assembly (Rad and Con mtd.) Subaru Brat 1.8,NAC,RAD.CHK-TYPE A AN1730 $25 A-Burlington Used Auto Parts USA-MA(Shirley) Request_Quote 1-800-228-5544 Request_Insurance_Quote 1981 Cooling Fan Assembly (Rad and Con mtd.) Subaru A Z74 $Call World Auto Parts USA-CA(Glendale) Request_Quote 818-240-1460/888-782-8781 Request_Insurance_Quote 1985 Cooling Fan Assembly (Rad and Con mtd.) Subaru A NN7 $Call World Auto Parts USA-CA(Glendale) Request_Quote 818-240-1460/888-782-8781 Request_Insurance_Quote 1982 Cooling Fan Assembly (Rad and Con mtd.) Subaru LH LH,1.8L,4SPD,PTC,CK TYPE A 203648 $Call Charlie's Used Auto Parts USA-TN(Dayton) Request_Quote 423-775-3046 / 800-933-7958 Request_Insurance_Quote 1981 Cooling Fan Assembly (Rad and Con mtd.) Subaru MOTOR AND BLADES 963404 $Call Schneider's Auto Wrecking Can-ON(Rostock) Request_Quote 1-800-565-4606 Request_Insurance_Quote 1986 Cooling Fan Assembly (Rad and Con mtd.) Subaru Brat 2DR,RED,7-86,1.8,FLR-MT 15966 $Call Nuwer Auto Parts USA-NY(Holland) Request_Quote 1-716-537-2800 Request_Insurance_Quote 1982 Cooling Fan Assembly (Rad and Con mtd.) Subaru CK MFR, SOLD AS ASSEMBLY, SILVER-BLUE 821251 $Call Roger's Auto Sales & Used Part USA-VA(New-Market) Request_Quote 540-740-8733 / 800-377-8302 Request_Insurance_Quote Quote Link to comment Share on other sites More sharing options...
Unknownjeremiah Posted June 2, 2019 Author Share Posted June 2, 2019 1 hour ago, sparkyboy said: The ea81 fan is smaller than ea82? I ask because the biggest flat rate box is $17 to ship I can see how an ea82 fan fits... I placed a reader for a mechanical temp gauge where the plastic plug goes for ea82 radiator and for a long time I just air flow cool my car. It's fine for the street so I would do that until your fan situation is in order. It is a bummer cause you can't go off roading. My car is getting too hot at long lights. I kinda need to have a fan. I commute 25 miles one way, going average of 60. Quote Link to comment Share on other sites More sharing options...
bratman2 Posted June 2, 2019 Share Posted June 2, 2019 (edited) The plug is cut off. I thought this fan was off my Brat. Might not have been. I salvaged some parts off an EA81 station wagon many years ago. If you don't mind splicing your plug on I do have the fan. I will check it with my 12v jump pack to make sure it runs and has no issues. Yes, fan works! Edited June 2, 2019 by bratman2 Add content 1 Quote Link to comment Share on other sites More sharing options...
Unknownjeremiah Posted June 2, 2019 Author Share Posted June 2, 2019 Yeah I’m interested in it. Let me know when you find out shipping and I’ll get money to you. Quote Link to comment Share on other sites More sharing options...
bratman2 Posted June 2, 2019 Share Posted June 2, 2019 Okay. I work 12 hour shift and start days tomorrow. Would not be able to get it out until Weds. If that is okay with you. I live in the sticks so we only have a small rural post office. Last time I was in there they did not even have a large flat rate box, only medium and small. If they don't have the large do you need the housing if the fan motor and blade would fit in a medium? Your fan the exact same as the one I posted? Just trying to cover the bases, lol! You can private message me you address. I took a few second video of the fan running if you would like it emailed to you? You can private message me your email too if you would like the small video. Figure maybe 5-6 dollars and the shipping. Quote Link to comment Share on other sites More sharing options...
Unknownjeremiah Posted June 2, 2019 Author Share Posted June 2, 2019 1 hour ago, bratman2 said: The plug is cut off. I thought this fan was off my Brat. Might not have been. I salvaged some parts off an EA81 station wagon many years ago. If you don't mind splicing your plug on I do have the fan. I will check it with my 12v jump pack to make sure it runs and has no issues. Yes, fan works! Looks like it’s the same. Quote Link to comment Share on other sites More sharing options...
bratman2 Posted June 2, 2019 Share Posted June 2, 2019 Yours looks nicer! Quote Link to comment Share on other sites More sharing options...
